How can display calling NUMBER and NAME on 4029 phone?
doublevand981
Post by doublevand981 »
Hi all,
i installing OXE crystal system Realease 9.0 for Hotel.
But now Guest called reception (4029) it displayed guest NAME only . so She don't know phone number (room number) of guest.
Any one face this issue PLs help how to config that 4029 phones can display both guest NUMBER and NAME on 4029 phones.
thanks so much
OXE_4400
Re: How can display calling NUMBER and NAME on 4029 phone?
Post by OXE_4400 »
You can insert number to name : Room#412_212
doublevand981
how can i do it?
by manually in check in procedure
or by PABX programing
or by ...>
Pls show me sir
doublevand981 wrote:how can i do it?
or by ...>
Pls show me sir
During heck in--> either in PMS or hotmenu.
doublevand981
can i do it on WinPac , sir?
hung.le
Post by hung.le »
As i know, 4029 digital phone can not display both name and calling number. It only can display either name or calling number.
I have opened a eSR for this case.
Rgds!
murraya
Post by murraya »
I have found to do this you need the 4039.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
gurjeetsingh200
Post by gurjeetsingh200 »
just configure 4039 set type in NMC programming for 4029 set
doublevand981
it's unique solution for this case. even that the phone will wrong display some function keys.
thanks
morio
Post by morio »
hi
i also face the same problem. name and number will be displayed when using a 4039 but does not work for 3029. so i just changed the phone type to 4039 but installed 4029. but you will face some problems as some feature keys will not display.
Return to “ON SITE TROUBLES”
