OLD / OHL Driver OXO - Not logging incoming calls
alan-sb
Post by alan-sb »
Hi all, Been working with the OXO's since release R3.1 but only just had my first request for call logging off an OXO! :shock:
I'm an IT guy rather than telephony so apologies before I start, the OXO is the only PABX I've ever worked on.
I'm trying to setup PABXSoft on a 14 day trial to see whether it can delivery what my customer needs for call logging. I've used these forums to good effect to get OLD v2.3.3 installed on my PC (Windows XP) and get it setup to talk to my test OXO (Release 5.1). After a few trials and tribulations (mainly resolved by manually editing the OhlDriver.conf file so that the service ran in Metering mode instead of Hotel mode) I've got it creating TicketCollector.xml files on my PC and I can see tickets being raised for each Outgoing call being made.
However I'm not seeing any Tickets being raised for Incoming calls (abandoned or connected) to my OXO. This is nothing to do with PABXSoft as the software just reads the TicketCollector.xml files and the incoming calls arn't producing Tickets. I'm pretty certain this is a setup on the OXO issue but I could do with some assistance in finding the right setting.
Thanks in adavnce for any assistance you can provide.
Best regards,
Alan
enio.eltz
Re: OLD / OHL Driver OXO - Not logging incoming calls
Post by enio.eltz »
Hi Alan
You need to configure the extensions to OXO sends tickets from incoming calls.
Best regards
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
et
Post by et »
In every subscribers/ details/ metering/ change Monitoring to "All calls" instead of "Outgoing Calls".
Return to “Applications”
