Hi all,
I have the following topology for my network:
7750-1 -------------------- 7750-2
7450-1 7450-2
Here, 7750-1 and 7750-2 are the two Service Routers with Alcatel 7750SR-1.
7750-1 and 7750-2 are the two Service switches with Alcatel 7750ESS-7. All the links are 10Gbps full-duplex links.
I have default network queue policy applied on all the ports. I'm sending 80% load (8Gbps full-duplex) from 7450-1 to 7450-2.
Now I'm observing that, the packets are getting dropped and the traffic is limited to 63% as shown below:
*A:7750-1# monitor port 1/1/1 rate
Monitor statistics for Port 1/1/1
Input Output
At time t = 0 sec (Base Statistics)
Octets 10910510779 10826883713
Packets 10665125 10393560
Errors 0 0
At time t = 10 sec (Mode: Rate)
Octets 772434176 766734964
Packets 755074 736047
Errors 0 0
Utilization (% of port capacity) 63.00 62.51
Here is my QoS settings:
*A:7750-1# show qos network-queue default detail
QoS Network Queue Policy
Network Queue Policy (default)
Policy : default
Description : Default network queue QoS policy.
Queue CIR PIR CBS MBS HiPrio PIR Lvl/Wght AvgOvrhd Parent
CIR Rule PIR Rule CIR Lvl/Wght
Named-Buffer Pool
1 0 100 def 50.00 10 n/a 0.00 No
closest closest n/a
(not-assigned)
2 25 100 3.00 50.00 10 n/a 0.00 No
closest closest n/a
(not-assigned)
3 25 100 10.00 50.00 10 n/a 0.00 No
closest closest n/a
(not-assigned)
4 25 100 3.00 25.00 10 n/a 0.00 No
closest closest n/a
(not-assigned)
5 100 100 10.00 50.00 10 n/a 0.00 No
closest closest n/a
(not-assigned)
6 100 100 10.00 50.00 10 n/a 0.00 No
closest closest n/a
(not-assigned)
7 10 100 3.00 25.00 10 n/a 0.00 No
closest closest n/a
(not-assigned)
8 10 100 3.00 25.00 10 n/a 0.00 No
closest closest n/a
(not-assigned)
9 0 100 def 50.00 10 n/a 0.00 No
closest closest n/a
(not-assigned)
10 5 100 def 50.00 10 n/a 0.00 No
closest closest n/a
(not-assigned)
11 5 100 def 50.00 10 n/a 0.00 No
closest closest n/a
(not-assigned)
12 5 100 def 25.00 10 n/a 0.00 No
closest closest n/a
(not-assigned)
13 100 100 def 50.00 10 n/a 0.00 No
closest closest n/a
(not-assigned)
14 100 100 def 50.00 10 n/a 0.00 No
closest closest n/a
(not-assigned)
15 10 100 def 25.00 10 n/a 0.00 No
closest closest n/a
(not-assigned)
16 10 100 def 25.00 10 n/a 0.00 No
closest closest n/a
(not-assigned)
FC UCastQ MCastQ
be 1 9
l2 2 10
af 3 11
l1 4 12
h2 5 13
ef 6 14
h1 7 15
nc 8 16
Associations
MDA : 1/1
MDA : 1/2
Port-id : 1/1/1
Port-id : 1/1/2
Port-id : 1/1/3
Port-id : 1/1/4
Port-id : lag-1
Port-id : lag-2
Here is my 7750-1 port 1/1/1 details:
*A:7750-1# show port 1/1/1 detail
Ethernet Interface
Description : 10-Gig Ethernet
Interface : 1/1/1 Oper Speed : 10 Gbps
Link-level : Ethernet Config Speed : N/A
Admin State : up Oper Duplex : full
Oper State : up Config Duplex : N/A
Physical Link : Yes MTU : 9212
Single Fiber Mode : No
IfIndex : 35684352 Hold time up : 0 seconds
Last State Change : 10/18/2009 08:39:17 Hold time down : 0 seconds
Last Cleared Time : 10/21/2009 04:05:59 DDM Events : Enabled
Configured Mode : network Encap Type : null
Dot1Q Ethertype : 0x8100 QinQ Ethertype : 0x8100
PBB Ethertype : 0x88e7
Ing. Pool % Rate : 100 Egr. Pool % Rate : 100
Ing. Pool Policy : n/a
Egr. Pool Policy : n/a
Net. Egr. Queue Pol: default
Egr. Sched. Pol : n/a
Auto-negotiate : N/A MDI/MDX : N/A
Accounting Policy : None Collect-stats : Disabled
Egress Rate : Default Ingress Rate : Default
Load-balance-algo : default LACP Tunnel : Disabled
Down-when-looped : Disabled Keep-alive : 10
Loop Detected : False Retry : 120
Sync. Status Msg. : Disabled Rx Quality Level : N/A
Configured Address : 00:21:05:7f:35:f0
Hardware Address : 00:21:05:7f:35:f0
Cfg Alarm : remote local
Alarm Status :
Transceiver Data
Transceiver Type : XFP
Model Number : 3HE00564AAAA01 ALA IPUIARRDAA
TX Laser Wavelength: 1310 nm Diag Capable : yes
Connector Code : LC Vendor OUI : 00:0a:1d
Manufacture date : 2009/05/22 Media : Ethernet
Serial Number : 953121A00655
Part Number : SXP3101LX-A8
Optical Compliance : 10GBASE-LR 10GBASE-LW
Link Length support: 10km for SMF
Transceiver Digital Diagnostic Monitoring (DDM)
Value High Alarm High Warn Low Warn Low Alarm
Temperature (C) +40.9 +80.0 +75.0 -10.0 -15.0
Tx Bias Current (mA) 45.1 100.0 80.0 0.0 0.0
Tx Output Power (dBm) -2.26 2.00 0.00 -7.00 -9.00
Rx Optical Power (avg dBm) -3.57 2.50 1.50 -15.51 -40.00
Aux1: 3.3 Voltage (V) 3.22 3.63 3.46 3.13 2.97
Traffic Statistics
Input Output
Octets 101282473015 100537796147
Packets 99007280 96517754
Errors 0 0
Ethernet Statistics
Broadcast Pckts : 0 Drop Events : 0
Multicast Pckts : 319 CRC/Align Errors : 0
Undersize Pckts : 0 Fragments : 0
Oversize Pckts : 0 Jabbers : 0
Collisions : 0
Octets : 201820269162
Packets : 195525034
Packets of 64 Octets : 422
Packets of 65 to 127 Octets : 1963436
Packets of 128 to 255 Octets : 30834
Packets of 256 to 511 Octets : 572
Packets of 512 to 1023 Octets : 138659
Packets of 1024 to 1518 Octets : 193391112
Packets of 1519 or more Octets : 0
Port Statistics
Input Output
Unicast Packets 99766008 97258141
Multicast Packets 160 162
Broadcast Packets 0 0
Discards 0 0
Unknown Proto Discards 0
Ethernet-like Medium Statistics
Alignment Errors : 0 Sngl Collisions : 0
FCS Errors : 0 Mult Collisions : 0
SQE Test Errors : 0 Late Collisions : 0
CSE : 0 Excess Collisns : 0
Too long Frames : 0 Int MAC Tx Errs : 0
Symbol Errors : 0 Int MAC Rx Errs : 0
Per Threshold MDA Discard Statistics
Packets Octets
Threshold 0 Dropped : 0 0
Threshold 1 Dropped : 0 0
Threshold 2 Dropped : 0 0
Threshold 3 Dropped : 0 0
Threshold 4 Dropped : 0 0
Threshold 5 Dropped : 0 0
Threshold 6 Dropped : 0 0
Threshold 7 Dropped : 0 0
Threshold 8 Dropped : 0 0
Threshold 9 Dropped : 0 0
Threshold 10 Dropped : 0 0
Threshold 11 Dropped : 0 0
Threshold 12 Dropped : 0 0
Threshold 13 Dropped : 0 0
Threshold 14 Dropped : 0 0
Threshold 15 Dropped : 7773869 8100249130
Queue Statistics
Ingress Queue 1 Packets Octets
In Profile forwarded : 0 0
In Profile dropped : 0 0
Out Profile forwarded : 85205101 88783563234
Out Profile dropped : 0 0
Ingress Queue 2 Packets Octets
In Profile forwarded : 5110820 3488079144
Out Profile forwarded : 0 0
Ingress Queue 3 Packets Octets
In Profile forwarded : 55257 31672216
Ingress Queue 4 Packets Octets
Ingress Queue 5 Packets Octets
Ingress Queue 6 Packets Octets
Ingress Queue 7 Packets Octets
In Profile forwarded : 80 6812
Ingress Queue 8 Packets Octets
In Profile forwarded : 155 10336
Ingress Queue 9 Packets Octets
Ingress Queue 10 Packets Octets
Ingress Queue 11 Packets Octets
Ingress Queue 12 Packets Octets
Ingress Queue 13 Packets Octets
Ingress Queue 14 Packets Octets
Ingress Queue 15 Packets Octets
Ingress Queue 16 Packets Octets
Egress Queue 1 Packets Octets
Out Profile forwarded : 93582340 97512532784
Out Profile dropped : 1129490 1176920952
Egress Queue 2 Packets Octets
In Profile forwarded : 1746192 1822430927
Egress Queue 3 Packets Octets
In Profile forwarded : 151634 122551576
Egress Queue 4 Packets Octets
Egress Queue 5 Packets Octets
Egress Queue 6 Packets Octets
Egress Queue 7 Packets Octets
In Profile forwarded : 76 6184
Egress Queue 8 Packets Octets
In Profile forwarded : 516 50510
Here are my questions:
(1) I can see Egress Queue 1 is dropping packets. How do I make sure that it won't drop any packets ?
(2) What is "Threshold 15 Dropped" under the show output of "per threshold MDA discard statistics" ?
Can someone, through some light on this?
Best Regards
Kiran
Alcatel 7750SR QoS problem: only 60% load is supported
Return to “7750 Service Router”
Jump to
- General topics
- ↳ Talk to the admins
- ↳ GENERAL
- ↳ Outside World
- ↳ PARTS
- ↳ Pre-Sales
- ↳ JOBS
- ↳ Remote assistance contracts
- ↳ Actis
- ↳ Equipement Pictures
- ↳ OT/OXE/OXO FEATURES REQUESTS
- ↳ Lucent Technologies
- IF YOU ARE NOT TECHNICALLY TRAINED ON THOSE PBX, PLEASE POST IN ONE OF THOSE FORUMS
- ↳ Beginner's questions about the Crystal Hardware
- ↳ Beginner's questions about the Common Hardware
- ↳ Beginner's questions about the (4400 / Enterprise) PHONE APPLICATION or OPERATING SYSTEM
- ↳ Beginner's questions about the OmniPCX OFFICE
- VOICE - Documentation
- ↳ OXE (Crystal / Common) - System Documentation
- ↳ 4760
- ↳ OXO - System Documentation
- ↳ Documentation
- VOICE - OXE (OmniPCX Enterprise)
- ↳ Shelf
- ↳ Media Gateway
- ↳ PWT/DECT System
- ↳ System
- ↳ Translator
- ↳ Classes of Services
- ↳ Attendant
- ↳ Users
- ↳ Users by profile
- ↳ Set Profile
- ↳ Groups
- ↳ Speed Dialing
- ↳ Phone Book
- ↳ Entities
- ↳ Trunk Groups
- ↳ External Services
- ↳ Inter-Node Links
- ↳ X25
- ↳ Data
- ↳ Application
- ↳ Specific Telephone Services
- ↳ ATM
- ↳ Event Routing Discriminator
- ↳ Security and Access Control
- ↳ IP
- ↳ SIP
- ↳ DHCP Configuration
- ↳ Alcatel-Lucent Series 8&9
- ↳ SIP Extension
- ↳ Encryption
- ↳ Passive Communication Server
- ↳ SNMP Configuration
- VOICE - OXE - Common topics
- ↳ MAIN
- ↳ ACTIS
- ↳ Asterisk
- ↳ Boards
- ↳ Bugs & Security issues
- ↳ Equipment Pictures
- ↳ Feature Request
- ↳ H323 / Sip
- ↳ IP / VoIP
- ↳ IP SECURITY / ENCRYPTION (Thales)
- ↳ ipTouch (40x8) issues and tricks
- ↳ Linux tricks
- ↳ MOH
- ↳ ON SITE TROUBLES
- ↳ Phones
- ↳ Sipfoundry
- ↳ Software Loading
- ↳ Swinst
- ↳ System Hacking
- ↳ Traces
- ↳ Usefull commands
- ↳ Voice Guides
- ↳ Wireless configuration and sets
- VOICE - OpenTouch
- ↳ MAIN
- ↳ OTEC - OpenTouch Enterprise Cloud
- ↳ OTBE - OpenTouch Business Edition
- ↳ OTMS - OpenTouch Multimedia Services
- ↳ OTSBC - OpenTouch Session Border Controller
- ↳ OTNS - OpenTouch Notification Service
- ↳ OTMC - OpenTouch Message Center
- ↳ OTFC - OpenTouch Fax Center
- ↳ OpenTouch Conversation
- ↳ Smart Guest Applications
- VOICE - BiCS
- ↳ MAIN
- VOICE - OXO
- ↳ MAIN
- ↳ Configuration
- ↳ 42xx Systems
- ↳ Networking
- ↳ H323 / IP / Pimphony
- ↳ Internet and related
- ↳ Applications
- ↳ Hotel mode
- ↳ DECT
- ↳ Hardware
- VOICE - Omni Suite
- ↳ OmniTouch 8400 Instant Communication Suite
- ↳ OmniTouch 8410 Instant Communication Web Services
- ↳ OmniTouch 8440 Messaging Software
- ↳ OmniTouch 8450 Fax Software
- ↳ OmniTouch 8460 Advanced Communication Server
- ↳ OmniTouch 8464 Meet-me Audio Conference Bridge
- ↳ OmniTouch 8660 My Teamwork Conferencing and Collaboration
- ↳ OmniTouch 8670 Automated Message Delivery System
- ↳ OmniTouch Contact Center Standard Edition
- ↳ OmniTouch Contact Center Premium Edition
- VOICE - Applications
- ↳ AECS - Alcatel Extended Communication Server
- ↳ Alcatel OpenTouch Customer Service
- ↳ Aviso
- ↳ Call Center SoftPanel (ALU ProServices)
- ↳ CCD / CCS / CCIVR
- ↳ Free Desktop
- ↳ GENESYS
- ↳ Hotel / Hospital
- ↳ Ip Desktop Softphone
- ↳ IpTouch Phones XML Applications
- ↳ MSAD
- ↳ MyIC (My Instant Communicator)
- ↳ My Messaging / IMAP
- ↳ My Teamwork (ex-eDial)
- ↳ OmniPCX Record
- ↳ OmniVista 4760
- ↳ OmniVista 8770
- ↳ OTUC
- ↳ PREMIUM / GCE
- ↳ Rainbow
- ↳ Ubiquity
- ↳ ENS - Emergency Notification Server
- ↳ VNA - Visual Notification Assistant
- ↳ VAA - Visual Auto Attendant
- ↳ VitalSuite
- ↳ VitalQIP
- ↳ Voicemail (46x5)
- ↳ XML Presentation Server & TAPI Server
- ↳ 4980 - WebSoftPhone
- ↳ 4625 Interactive Voice Response
- VOICE - Third Party Applications
- ↳ AGITO NETWORKS
- ↳ AUDIOCODES
- ↳ ASTERISK
- ↳ AVST
- ↳ CDR Real time on Ethernet
- ↳ CISCO
- ↳ NGINX
- ↳ NICE
- ↳ Notification Systems
- ↳ OAK
- ↳ SOURCE TECH
- ↳ systel
- ↳ IP Touch apps
- ↳ Click2Dial
- ↳ MYIC apps
- Voice - Virtualization
- ↳ AWS
- ↳ HyperV
- ↳ Linux KVM
- ↳ Proxmox
- ↳ VmWare
- ↳ Other
- Alcatel Unleashed tools, documentations, and misc files...
- ↳ GitHub Script Repository
- ↳ "Home Made" documentations
- ↳ Alcatel Misc Documentation
- ↳ OFFICIAL TC's
- ↳ DIALER
- ↳ infocollect
- ↳ ipview analyzer
- ↳ motview
- ↳ sngrep
- ↳ VM_BACKUP
- ↳ Other Alcatel-Lucent tools
- Developer's corner
- ↳ AHL / OHL
- ↳ Alarming, Notification & Location
- ↳ CCTI / CCA
- ↳ CSTA
- ↳ My IC Phone
- ↳ My IP Touch Service for Enterprise
- ↳ O2G
- ↳ OmniVista 8770 User Provisioning
- ↳ SIP
- ↳ TAPI
- ↳ TSAPI
- ↳ Web Services
- Alcatel Data Equipment
- ↳ Security
- ↳ OmniAccess 3500 Nonstop Laptop Guardian
- ↳ Mobility
- ↳ OmniAccess WLAN Switching Systems
- ↳ OmniAccess WLAN 4302
- ↳ OmniAccess Wireless Access Points 41
- ↳ OmniAccess Wireless Access Points 65
- ↳ OmniAccess Wireless Access Points 60/61/70
- ↳ OmniAccess Wireless Access Points 80M
- ↳ Mobile IP Phones
- ↳ OmniAccess Devices
- ↳ OmniAccess 5780
- ↳ OmniAccess 5740
- ↳ OmniAccess 5510
- ↳ Network Management
- ↳ Omnivista
- ↳ Omnivista Mobility Manager
- DATA - Documentation
- ↳ Technical papers
- ↳ Troubleshooting guides
- DATA - Lan Switching
- ↳ OmniSwitch 10k
- ↳ OmniSwitch 9900
- ↳ OmniSwitch 9000 / 9000E
- ↳ OmniSwitch 6900
- ↳ OmniSwitch 6865
- ↳ OmniSwitch 6870
- ↳ OmniSwitch 6860 / 6860E
- ↳ OmniSwitch 6855
- ↳ OmniSwitch 6850 / 6850E
- ↳ OmniSwitch 6560 / 6570M
- ↳ OmniSwitch 6465
- ↳ OmniSwitch 6450
- ↳ OmniSwitch 6400
- ↳ OmniSwitch 6360
- ↳ OmniSwitch 6350
- ↳ OmniSwitch 6250
- ↳ OmniSwitch 2220
- ↳ OmniSwitch 2260 / 2360
- ↳ Legacy Devices (OS4024, XOS, OmniCore)
- ↳ OmniSwitch 6600 / 7000 / 8800
- ↳ OmniSwitch 6800
- ↳ OmniStack LS 6200
- ↳ Misc
- DATA - WLAN, Mobility and WAN
- ↳ OmniAccess WLAN Switching Systems (OEM)
- ↳ Mobile IPTouch Phones (MIPT)
- ↳ OmniAccess Stellar Express
- ↳ OmniAccess Stellar Enterprise
- ↳ Brick VPN Firewall
- ↳ OmniAccess 5740/5780
- ↳ OmniAccess ESR 5720
- ↳ OmniAccess 5510
- DATA - Network Management
- ↳ OmniVIsta 3600 Air Manager
- ↳ OmniVista 2500 v4.x
- ↳ OmniVista 2500 v3.5
- ↳ OmniVista 2500/2700 v3.4 and older
- ↳ OmniVista Cirrus
- ↳ Alcatel Quarantine Manager
- ↳ Fortigate Security
- DATA - Service Provider
- ↳ 5520 ASAM
- ↳ 5620 SAM
- ↳ 5650 CPAM
- ↳ 5670 RAM
- ↳ 5750 SSC
- ↳ 7210 SAS
- ↳ 7360 ISAM
- ↳ 7450 ESS
- ↳ 7450 Ethernet Service Switch
- ↳ 7750 Service Router
- ↳ 7705 SAR
- ↳ 7750 SR
