VM 4645- "This mail box is already used by someone else
olebon
Post by olebon »
A user on OXE MG with 4645 can not reach his voicemail box, the system plays the voiceguide "This mail box is already used by someone else". I deleted and recreated the box from 4760 - no changes. I deleted the box from Eva_tool and recreated it using 4760 - the problem did not go. I deleted the user account and recreated 15 minutes later with 4760- the same voiceguide.
What else can I do?
auditmevo
jasonwal
I had this problem before.
Post by jasonwal »
Alcatel TAC Basically told me to reboot the Voicemail. it's caused by a hung port. if you run vmail it should show you the port that is hanging.
I tried Running Eva_tool to rest the port but it did not work so I rebooted and it cleared up.
olebon
Post by olebon »
Thank you
BIT_man
Re:
Post by BIT_man »
frank wrote:auditmevo
A user of mine had this same problem yesterday (i.e. "This mail box is already used by someone else..."). I tried using Eva_tool to reset the all the ports and nothing. Disable and enabled all the lines and no luck. Eventually I had to re-boot the system during off hours. Is there a way to fix this without haveing to reboot? If "auditmevo" is the solution, what exactly does it do?
torrentula
Re: VM 4645- "This mail box is already used by someone else
Post by torrentula »
Yes, what is auditmevo?
You do not have to reboot the entire system. Just reset the GD on shelf 18 (that's the vmail shelf) :lol:
Certain releases the vmail doesn't come back up and an entire reboot is than necessary. But it seems they have fixed that in later releases.
tincho.rn
Post by tincho.rn »
torrentula wrote:Yes, what is auditmevo?
This tools is to synchronice database netween 4645 and CS. It could help.
BIT_man
Post by BIT_man »
It happened again! I ran the "incvisu" command and this is what it looked like at the time of error. Any thoughts? Anyone?
16/11/07 13:16:38 001010M|00/00/0/000|=4:0426=IPTOUCH terminal reset 13,(0,0),00:80:9f:57:59:2b,5203
16/11/07 13:16:39 001010M|19/01/0/030|=5:2053=Terminal 30 in service
16/11/07 13:17:17 001010M|18/01/-/---|=4:5400=4645 Software Error: Error Code 0x 0. 0 Module 0x 0. 0 Line 0x d.58
16/11/07 13:17:17 001010M|18/01/-/---|=4:5402=4645 Error Data: 0x005f 0x0008 0x0003 0x0000 0x0000
16/11/07 13:17:17 001010M|18/01/-/---|=4:5400=4645 Software Error: Error Code 0x 0. 0 Module 0x 0. 0 Line 0x1a.5c
16/11/07 13:17:17 001010M|18/01/-/---|=4:5402=4645 Error Data: 0x091e 0x0000 0x8000 0x13d5 0x0000
16/11/07 13:17:17 001010M|18/01/0/254|=2:1401=ABCA task 32 exception 14 PC 0x080b04dc
16/11/07 13:17:17 001010M|18/01/0/254|=2:1401=ABCA task 15 exception 0 PC 0xffffffffffffffff
16/11/07 13:19:08 001010M|18/01/0/001|=3:1404=ABCA Wrong MSG 35 IE 63 4626: 3
16/11/07 13:19:16 001010M|18/01/-/---|=4:5400=4645 Software Error: Error Code 0x 0. 0 Module 0x 0. 0 Line 0x d.58
16/11/07 13:19:16 001010M|18/01/-/---|=4:5402=4645 Error Data: 0x0025 0x0003 0x0003 0x0000 0x0000
16/11/07 13:19:16 001010M|18/01/-/---|=4:5402=4645 Error Data: 0x001d 0x0003 0x0003 0x0000 0x0000
16/11/07 13:19:16 001010M|18/01/-/---|=4:5400=4645 Software Error: Error Code 0x 0. 0 Module 0x 0. 0 Line 0x1a.5c
16/11/07 13:19:16 001010M|18/01/-/---|=4:5402=4645 Error Data: 0x0903 0x0000 0x8000 0x13d5 0x0000
16/11/07 13:19:16 001010M|18/01/0/254|=2:1401=ABCA task 32 exception 14 PC 0x080b04dc
16/11/07 13:19:16 001010M|18/01/0/254|=2:1401=ABCA task 15 exception 0 PC 0xffffffffffffffff
16/11/07 13:19:17 001010M|18/01/-/---|=4:5400=4645 Software Error: Error Code 0x 0. 0 Module 0x 0. 0 Line 0x d.58
16/11/07 13:19:17 001010M|18/01/-/---|=4:5402=4645 Error Data: 0x0002 0x0003 0x0003 0x0000 0x0000
I ran a "shutdown -r now" to reboot the OXE and the problem was gone.
olca
Post by olca »
Hello BIT_man,
Looking at the incidents you posted, we have some errors in ABCA messages between the 4645 and CS, as the incident 1401 is pointing to the GD on shelf 18 which is 4645. Normally when ever you have some error in working of 4645 we see incidents 5400 and 5402.
If the issue is recurring, I would suggest to open a ticket with Alcatel with all the information. I understand that it takes a long time for Alcatel to fix if its really an issue in their S/W, but there is no other GO. :-(
OLCA
chris.raper
Post by chris.raper »
We believe this is a bug. We have had 3 different sites all running R7.1 have the issue. We currently have a SR open with TSS however we have not been able to reproduce the issue in the lab.
These are running standalone 4645 on CS's.
I agree that you should log a SR with Alcatel to report the issue. We have not been able to find a way around the issue without rebooting, sorry. :?
Return to “Voicemail (46x5)”
