cant call from OXE to OXO SIP
ccube
Post by ccube »
HAHA. Ok.
djsonico
Re:
Post by djsonico »
ccube wrote:Hello Xero. Can you please send me the configuration you made on your OXE? I was able to make OXE to OXO calls recently in my LAB. I did not encountered the issue that you mentioned. Please send me the OXE's config and I would gladly help you.
Hello ccube...
I need to deploy a inter-conexion between OXE and OXO. I need to use a SIP Trunk. How can I do that...
1) I need to configurate una internal gateway per pbx. (one to OXE and one to OXE)??
2) The configurate the ARS to route the calls between the pbxs???
I need to understand the theory...
Best regards,
dj.-
ccube
Re: cant call from OXE to OXO SIP
Post by ccube »
Hi djsonico,
I am sorry for the late reply. Please check OXE and OXO documentation for SIP interconnection. You can find all the necessary information there.
Return to “SIP”
