INT-IP2 card not work
Usually not necessary to create lanpbx file. At first - you have
"0000001D-0000085D: ConfigIP : Query Default Router 192.168. 1.100
using ICMP ECHO REQUEST .....................
0000001E-000018D9: ConfigIP : Ethernet check success..........
0000001F-000020B4: ConfigIP : No response from Default Router [fsk status=0x01]"
Connect (instead of INTIP) PC with address 192.168. 1.254 and try to ping CPU.
Next one - show "netadmin -m", menu 2 (global view) (do you have the same netmask on CPU, role IP addressing, security activated).
And last (at this moment) - if you change CPU address - you need restart (for tftp services working).
doublevand981
dear Frank and Vad,
below is results as your requests:
(1)viscohn> twin
Wed Jun 30 10:51:55 CEST 2010
Usage : twin [Redundancy Cpu Enable (y/n)]
Role and CPU positions:
Role of the CPU : MAIN
CPU position : 06
CPU address : 192.168.1.100
Twin CPU position : UNKNOWN
Twin CPU address : UNKNOWN
Redundancy State:
Duplicated configuration : NO
Transmission CPU-CPU : KO
Telephony redundancy : KO
monitel redundancy : KO
memloader redundancy : KO
All applications redundancy : KO
(1)viscohn> more etc/hosts
etc/hosts: No such file or directory
(1)viscohn> ifconfig -a
eth0 Link encap:Ethernet HWaddr 00:80:9F:74:D0:97
inet addr:192.168.1.100 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:29944 errors:0 dropped:0 overruns:0 frame:0
TX packets:3601 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:100
Interrupt:5 Base address:0xb000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:728 errors:0 dropped:0 overruns:0 frame:0
TX packets:728 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
(1)viscohn> more /usr4/mao/lanpbx.cfg
/usr4/mao/lanpbx.cfg: No such file or directory
(1)viscohn> netadmin -m
Alcatel e-Mediate IP Network Administration
1. 'Installation'
2. 'Show current configuration'
3. 'Local Ethernet interface'
4. 'CPU redundancy'
5. 'Role addressing'
6. 'Serial links (PPP)'
7. 'Tunnel'
8. 'Routing'
9. 'Host names and addresses'
10. 'Copy setup'
11. 'Security'
12. 'DHCP configuration'
13. 'SNMP configuration'
14. 'VLan configuration'
15. 'Node configuration'
16. 'Ethernet redundancy'
17. 'History of last actions'
18. 'Apply modifications'
0. 'Quit'
What is your choice ? 2
Your system hasn't any site number.
Private IP addressing space: no
Restricted internet accesses: no
Accept ICMP redirect: yes
Low dynamic ports range configuration : 10000 - 10499
There is no VLan configuration. No frame will be 802.1q-tagged.
The ethernet redundancy is not supported on this CPU type
node name : node000000
internal name resolver activated : no
Ethernet interface setup
Netmask : 255.255.255.0
| Machine type | Local interface | Name | Address |
| local | Ethernet | viscohn | 192.168.1.100 |
<return> to continue.
i did not use sercuritty and also tried to reset CPU some times
(1)viscohn> twin
CPU position : 06
Redundancy State:
1. 'Installation'
4. 'CPU redundancy'
7. 'Tunnel'
8. 'Routing'
10. 'Copy setup'
11. 'Security'
0. 'Quit'
doublevand981
doublevand981
Dear frank,
below is results:
(1)viscohn> more /etc/hosts
10.253.253.1 xa000000
10.253.253.2 xb000000
10.253.253.3 xma000000
10.253.253.4 xmb000000
10.253.253.10 adm000000_1
10.253.253.11 adm000000_2
10.253.253.20 app000000_1
10.253.253.21 app000000_2
127.0.0.1 loopback
255.255.255.0 subnetmask
192.168.1.235 PCconfig
192.168.1.4 PCdoanh
192.168.1.15 Chaupc
192.168.1.100 viscohn maincpu standcpu node000000 localhost
RX packets:40229 errors:0 dropped:0 overruns:0 frame:0
TX packets:4642 errors:0 dropped:0 overruns:0 carrier:0
RX packets:740 errors:0 dropped:0 overruns:0 frame:0
TX packets:740 errors:0 dropped:0 overruns:0 carrier:0
RX packets:40240 errors:0 dropped:0 overruns:0 frame:0
TX packets:4648 errors:0 dropped:0 overruns:0 carrier:0
(1)viscohn> cdmao
/DHS3data/mao
(1)viscohn> more lanpbx.cfg
Hi Vad,
i disconnected V24 cable.
i checked trapping with default factory. the system using 01 ACT14 shefg number 0.
below is results:
127.0.0.1 loopback
192.168.1.4 PCdoanh
192.168.1.15 Chaupc
(1)viscohn> cdmao
/DHS3data/mao
Hi Vad,
doublevand981
hi all,
below is results:
(1)viscohn> lanpbxbuild -auto
Wed Jun 30 12:59:26 CEST 2010
IP CPU 1: 192.168.1.100
Are you sure (Y/N):y
Permission denied.
Permission denied.
(1)viscohn> cdmao
/DHS3data/mao
(1)viscohn>
below is results:
Permission denied.
Permission denied.
(1)viscohn> cdmao
/DHS3data/mao
(1)viscohn>
