Try this I wrote it a long time ago but it should still be valid.
viewtopic.php?f=310&t=12665
K.
LOLA Problem
- Krusty65
Re: LOLA Problem
- giovanni.attolini
Re: LOLA Problem
Maybe the file was removed. "The selected attachment does not exist anymore."
Giovanni A. Attolini
- Krusty65
Re: LOLA Problem
You are quite correct, I did say that it was done a lone, long time ago.
I will add it here when I figure out what I did with it.
K.
K.
- Krusty65
Re: LOLA Problem
Found it
Hopefully it is still relevant.
K.
K.
Re: LOLA Problem
The easy way, and it works for me, put the oxo firmware on a flash drive ou external hdd unit.
Enviado do meu Edison 3 através de Tapatalk
Best Regards
Jose Alves
Jose Alves
