LOLA Problem
LOLA Problem
Dear all,
I was loading software on CPU 4.When I connect the PC with the system & starts downloading It immediatly shows the message Missing file/boot/config/.rc.
Then i tried it with another LAPTOP but of no use.Same message appeared.
I tried everything, put software in the Root Directory,tried with cross over cable,checked registry edit settings,disabled the anti-virus,disabled firewall settings.
But when my senior tried to do the same ,he succeeded.He said there is some problem with the PC.
With thanks & Regards,
Ravinder Singh
Engineer
Ravinder Singh
Engineer
- Konstantinos.E
louisj
etc
Red_Hunter2010
Re: LOLA Problem
Have had the same problem and I had to share the system software folder with read/write permissions.
libexec
Re: LOLA Problem
"Microsoft File and Printer sharing in Network settings" +1 here, was beating my head hard for 2 days after realized it...
