Yes the CallServer is declared on System->CallServer section and also declared as an associated server on Configuration->Server section.
I don't know what is wrong, the application "MY_M" is still on status "UNINSTALLED" on the CallServer...
thanks for your help
OmniTouch 8440 Presentation Server
bibou
Re: OmniTouch 8440 Presentation Server
I tried to declared my CallServer as an associated server but with no results...
One Question : what IP adress of the CallServer must but declared on the 8440 server?
Is it the role Main @ or the Physical @? because currently the FQDN of the callServer is associated to the role Main IP @.
thanks again
thanks again
bibou
I've Solved my problem!!!
It was the Security Module (MSM box) behind the Voicemail 8440 that was causing the problem.
After unsecuring the Voicemail with the MSM BOX on the CallServer (with config_BT.cfg regeneration) the Messaging feature appeared on IPTOUCH
bibou
Does someone knows if the Messaging feature (A8440 Voicemail button on the phone Menu) works on Digital 40x9 phones?
