Its available in the page no 8 of the TC0910. Please check if your PC is a part of those approved.
4058/4059
Eliott_DUP
Re: 4058/4059
Nowhere. But my info is:Patrick. wrote:Where can I find Info about these modifications?
It's a special modification in the BIOS for the keyboard chip.
It slows down the input speed to prevent a buffer overflow in the TA Box.
This modification is done for some HP and Compaq PC's only.
Patrick.
Re: 4058/4059
Thx, but as you can see in my primary post we don't have a "Ta box" connected to our systems, we also do not connect a MMK keyboard. This system aught to work just fine without these extras, proof being a config running under Win95 since approx 6 years.
We are implementing a config as described in TC0910 page 19 "6.6. Connecting A4058 MIG Console" but with "6.6.2. On a 4035 set".
Re: 4058/4059
Exist new 4059 version 5.0.2
serge
Re: 4058/4059
Any idea where this is available? Our supplier says their is no newer version availabale?
Re: 4058/4059
Don't trust.
Re: 4058/4059
hi! try an compatible hp mashine! it will work.... the developer (pierre verlet or so) say, he design it only for hp chips....
bad english is the language of the future!
torrentula
Re: 4058/4059
I have run 4059 on Dell boxes without problem. White boxes with 945 chipset normally do not work.
Compaq is definitely recommended
