4058/4059
Patrick.
4058/4059
Post by Patrick. »
I've just installed 4058/4059 on two different XP pc's.
The config is:
A 4035 with a 4094CTI module is connected to the PC on com1.
On first sight there seems to be no problem and the app works just fine but if I try to configure a Function button I get the following message:
Title window= 4059MAX.exe Application error
The instruction at "0x00444bbf" referenced memory at "0x000000000"
The memory could not be read
<OK> <Cancel>
Clicking OK or Cancel causes the application to abort either way.
This error appears on both PC's
Does anyone have a explanation for this problem?
Thx,
Patrick
Eliott_DUP
Re: 4058/4059
Post by Eliott_DUP »
Which A4059 Version? 4.016.9?
serge
Re: 4058/4059
Post by serge »
Hi there,
It seems to be 4.014.13.
Is there a free upgrade available? We don't want to buy a fully new softwarepackage.
Rgrds
S.
OXE_4400
Re: 4058/4059
Post by OXE_4400 »
Costs licence, not SW versions
serge
Re: 4058/4059
Post by serge »
Sorry,
This is the version which is running in another site, the version that's gives problems is 4059_4.016_9 on XP machine.
Rgrds
S.
OXE_4400
Re: 4058/4059
Post by OXE_4400 »
Doesn't exist newer SW, I think You need to open eSR.
serge
Re: 4058/4059
Post by serge »
Alternatives?
OXE_4400
Re: 4058/4059
Post by OXE_4400 »
Do You have TC0910? Exist restriction, compatibilities,...
soori1905
Re: 4058/4059
Post by soori1905 »
What is the service pack on Windows XP and are you having the PC compliant with Alcatel BIOS modifications ??
Patrick.
Re: 4058/4059
Post by Patrick. »
We do have the TC0910.
SP=2
PC compliant with Alcatel BIOS modifications??...
Sounds interesting. Where can I find Info about these modifications?
Return to “Attendant”
