OmniVista 4760 change IP
Re: OmniVista 4760 change IP
This is not right. it relys on the release, from what i know with vital suite you have to do ti in the right way!
edwintufis
Re: OmniVista 8770 change IP
Unfortanally i dont have access to the documentation or software or licenses, i only have access to AlcatelUlseashalex wrote: ↑03 Apr 2017 15:54There is a complex cognitive process of decoding symbols in order to construct or derive meaning. It is called reading.
If you use that sacred process to the document "8770 Installation manual" which is properly supplied with 8770 SW you'll find the chapter named "5.7 Modifying the Server FQDN or IP Address".
You do not have Tools\Documentation\Installation manual\ folder in your 8770 distro? That's bad. Ask your supplier for 8770 Docs CD. I would upload it but it is not possible to load files bigger than 2 MB and the file is 2,4 MB.edwintufis wrote: ↑04 Apr 2017 11:15Unfortanally i dont have access to the documentation or software or licenses, i only have access to AlcatelUlseashalex wrote: ↑03 Apr 2017 15:54There is a complex cognitive process of decoding symbols in order to construct or derive meaning. It is called reading.
If you use that sacred process to the document "8770 Installation manual" which is properly supplied with 8770 SW you'll find the chapter named "5.7 Modifying the Server FQDN or IP Address".that helps me alot
