Alcatel to NEC using E1 - QSIG GF
dandy
Re: Alcatel to NEC using E1 - QSIG GF
Post by dandy »
Thanks to patmul39 and haroun,
It is related to NEC management. The NEC engineer modify the setting by putting 3599 in a separate table.
dandy
Post by dandy »
By the way, it is possible to seize the trunk from NEC using Alcatel Extension? What type of method we need to use?
Thank you.
patmul39
Post by patmul39 »
Since it's a link between 2 pbx's, I would probably create a Routing number
patmul39
Post by patmul39 »
Dandy
I have a customer with an NEC Dect solution having AP200 and AP300 and we are trying to get it to talk to the OXE. His problem is the AP200 which are not (apparently) SIP compliant so they might have to manage a QSIG link to the OXE. They have an SV7000 and 2x MG2M boards - can these 2 boards be managed to work as QSIG/ISDN cards? The other and preferred option would be to convert the AP200 to AP200S and hence run everything over SIP.
As you have already managed to get the NEC and Alcatel talking via QSIG, I was wondering what boards have been used on the SV7000?
Return to “Trunk Groups”
