call routing route list creation
DjeSan
Re: call routing route list creation
Post by DjeSan »
haroun wrote: 13 Dec 2023 10:01 add a second temporal route with route number =2
Here's a little diagram, I tried to create a route, but it didn't work.
DjeSan
Post by DjeSan »
342 M ABC-IP Access Number = 0/ 0
oldboy
Post by oldboy »
You dont need ABC_IP for this
you dont need a new entity from what i understand you have a different mobile number prefix that you want to use TG 16 and all other numbers use TG 10 (correct me if i am wrong)
So lets use example 8xxxxxxxxx for TG 10
5xxxxxxxxx for TG 16
External Number plan 0 8xxxxxx ARS list 1
External Number plan 0 5xxxxxx ARS list 2
ARS Route List 1, RL 1 Route 1 TG 10 and Timed based Route list 1
ARS Route List 2, RL 2 Route 1 TG 16 and Timed based Route list 1
and 9 ARS selection looking at Discriminator 0 and to make sure correct go to Entity D/H then Disc Selector of the Entity used by users and make sure Discriminator 00 matches the external number plan that the 2 numbers are created in above
DjeSan
Post by DjeSan »
oldboy wrote: 17 Dec 2023 23:50 You dont need ABC_IP for this
Everything is clear except your last sentence: do I make these modifications from 4400 node 0 or ACT 14?
Let me explain, the calls come from ACT 14 to 4400 node 0, but the problem is that 4400 node 0 isn't sending the calls to the right beam.
DjeSan
Post by DjeSan »
go to Entity D/H
What does mean D/ H ?
Sorry, I don't speak English very well, so I'll try to translate your words to make them easier to understand in French.
DjeSan wrote: 18 Dec 2023 04:16
go to Entity D/H
lol ; IN SOME OF YOUR POSTS , we can cleary see that you're able to Go D/H
D/H=DOWN IN HIERARCHY =DESCENDRE EN ARBORESENCE , SOUS ITEM ETC....
BY THE WAY YOUR ACT 14 BELONGS TO THE NODE0te management is done in its cpu
DjeSan
Post by DjeSan »
haroun wrote: 18 Dec 2023 08:33
go to Entity D/H
i agree with you but please be indulgent the translations are not the same in french and english i'm really trying to understand
oldboy
Post by oldboy »
DjeSan wrote: 18 Dec 2023 15:08
Sorry about that :D
DjeSan
Post by DjeSan »
use the same prefix (9) for external calls on both nodes
I've created a second route (Sip gateway) using beam 10 on ACT 14, hoping that when we press 9 for external calls we'll use this route, but they're still using route 1 with beam 16.
please help me i've been using alcatel for e years and thanks to this forum i've learned a lot i'd like to reduce phone costs
Return to “Translator”
