Hello everyone, I hope you're all well.
we have a 4400 oxe r10 central (A) connected to a crystall managed a via an intof INTOF card (B) for the auxiliary crystall to make calls it goes through the 4400 and the latter is connected to a GSM gateway (Dinstar) for our external calls the concern, is that on the auxiliary crystal some calls are routed through analog GSM gateways (2N® EasyGate) and I'd like to create another route so that when we dial certain numbers, the calls go through the Dinstar gateway and not the analog gateways my concern lies at this level I'll send you the configurations and tell me what you need.
ps: I've tried configuring another route but nothing came up
route 2 is the one I tried to create to reach the GSM gateway from the auxiliary crystal (which passes through the 4400 via the intof)
call routing route list creation
Re: call routing route list creation
Not clear - what you want to do.
If you need another route for some external numbers:
- you need to create two different ARS route lists (with route etc.) f.e. ARS lists 1 and 2
- in discriminator rules - manage for some numbers ARS list 1 and for some numbers ARS list 2.
Hello, thank you for answeringvad wrote: ↑12 Dec 2023 21:56 Not clear - what you want to do.
it's for internal numbers that make external calls sir
we make external calls by dialing 9 ( Ars beam socket prefix with overlap ) when we enter 074 the calls are directed to an external GSM gateway but we have two gateways one GSM and the other analog and I would like to direct the calls to the GSM gateway ( for the auxiliary crystal )
I've created a route, but it's impossible to route the calls via this route.
add a second temporal route with route number =2
If you want to use different TG for users in main and auxiliary crystal you can:
- declare for users in main and auxiliary crystal different entity (f.e. 1 amd 2)
- in Entity declare TG (GSM in one and analogue in next)
- in ARS route declare - TG source - Entity.
In ARS route list you have - Origine du faisceau. Declare Entity instead of route. Will be used TG from Entity (and users from Entity 1 and 2 can use different TG for the same route).
Pour cela, c'est okai mais à quel endroit on déclare le trunk dans l'entité svp
I've created an entity and a second route, added beam 10, but when I try to call it congestion marker
