SIP Trunk Release 9.1 Problem
Re: SIP Trunk Release 9.1 Problem
At first - try to make a call from internal set (declear for test user - the same Public network COS and Entity as in incoming TG).
Guilherme Arthur
Post by Guilherme Arthur »
frank wrote: 24 Jul 2024 13:22 can you share traces
Hi Frank,
Sorry for the delay, I was unable to access the client.
PSTN (R2) ---- SIP TRUNK ABC --- the call completes, there is an answer but it drops in 2 seconds.
follow the motortrace.
when the trunk in PSTN (R2) --- SIP TRUNK ISDN - the call does not complete, and does not generate traces in SIP.
If you can help me I would really appreciate it!
Guilherme Arthur
haroun wrote: 05 Aug 2024 15:26 speed dialing
73700
Number= #100073700
transit call ? i rermember an issue with incoming call to an abrv number it doesn't work even in the isdn to isdn transit call
I understand, and how should I use the ISDN trunk if it is not with speed dialing?
thanks.
Guilherme Arthur
vad wrote: 05 Aug 2024 22:56 At first - try to make a call from internal set (declear for test user - the same Public network COS and Entity as in incoming TG).
Yes, with the ABC-F trunk, calls with internal extensions work normally.
The problem is when the call is directed from the PSTN (R2) to the SIP trunk. by DDI
alex
Post by alex »
Guilherme Arthur wrote: 13 Aug 2024 15:26
It's time to show R2 traces
Guilherme Arthur
alex wrote: 14 Aug 2024 05:22
Hello, but in the case with ABC-F trunk the call works, but drops out after 3 seconds.
Couldn't you see anything through motortrace?
what type of R2 trace would be good to analyze?
because what the call doesn't reach is with the SIP trunk in ISDN
THANKS!!
Guilherme Arthur wrote: 13 Aug 2024 15:25
73700
Number= #100073700
thanks.
by using routing number OR NETWORK NUMBER EXEMPLE
Call comes from PCMrR2, called is TRANSCODED TO 2000 WHICH is a fax server box routed via oxe by sipabcf (net 14 &trunkgp 1799 abcf minisip)
Prefix Planqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Instance (reserved) : 1 x
x Number : 2000 x
x x
x Prefix Meaning + Network No. x
x Network Number : 14 x
x Node Number/ABC-F Trunk Group : 1799 x
x Number With Subaddress (ISDN) + NO x
x Type + Fax Server x
x Identifier : 0 x
x
ROUTING nUMBER
x x
x Number : 3898 x
x x
x Prefix Meaning + Routing No. x
x Number of Digits : 8 x
x Default X25 ID.pref. + NO x
x
again with sip-isdn use routin/number instead of spd number
yep time to show r2 traces
alex
Post by alex »
Guilherme Arthur wrote: 14 Aug 2024 18:05
Nothing.
Its just BYE which is send from OXE immediately after ACK.
Check here https://www.alcatelunleashed.com/viewto ... 824#p62824
One step at a time.
Both SIP-ABCF and SIP-ISDN is not working in your case - so just stop at one certain signalling and explore it.
Return to “SIP”
