SIP Trunk Release 9.1 Problem
Guilherme Arthur
Hello everything is fine?
Could you help me?
I'm trying to set up a SIP trunk with a CallCenter system.
I made all the configuration that works in current releases 12.4, R100 for example.
However, this OXE is in release 9.1
trunk ABC-F
SIP Trunk
Network Routing
everything configured correctly.
However, when I try to dial from an internal OXE extension to network Numer that forwards to SIP, the message "extension unavailable" returns.
Checking the motor trace, I realized that when the invite is made, the IP of the OXE is going and not the SIP server.
can anybody help me?
1720117576 -> REQUEST URI : <> 7300@192.168.36.240:5060 ; user=phone
1720117576 -> FROM : <Gerente ADM> 9608@192.168.36.240:5060 ; user=phone
1720117576 -> TO : <> 7300@192.168.36.240:5060 ; user=phone
7300 is Network number
9608 is analog phone
IP OXE 192.168.36.240
IP TRUNK SIP 192.168.4.20
and as a result, nothing arrives in the trace for the SIP trunk
Could you help me?
trunk ABC-F
SIP Trunk
Network Routing
- frank
Re: SIP Trunk Release 9.1 Problem
Did you reboot the system after creating your SIP Gateway?
Use ISDN-All-Countries for SIP TRUNK.
ABC-F is reserved for ALE Products.
Guilherme Arthur
Yes, I managed to make it work in parts.
I created it as ISDN-ALL, but now internal OXE calls work.
However, coming from the R2 trunk, and sending it via DDI, it doesn't work.
It doesn't even hit the motorsip, but the internal ones work normally.
Guilherme Arthur
It seems to me that there is some blockage for the R2 trunk to connect to the SIP trunk
- I created SIP trunk 100 with network 2 (ISDN All Countries).
-SIP extgw = 100
-Network routing table =2
SIPGATEWAY = 100
-prefix #1000 Ars. Prof. Trg. Grp. Seiz. With. overlap. Discriminator: 2
- have 4 antities all discriminator selector 2 = 2
- numbering Discriminator 2
- Call number
73700
Area1
ARS Route List 200
Number of Digits 5
-ARS 200
time based route list = 1
Numberling command table = 1
-command table
carrier =0
command=I
sipgateway= 100
-ARS CONFIG:
trunk group 100
command table = 1
NPD 255
Quality + speech
-speed dialing
73700
Number= #100073700
Is there anything else missing?
calls from OXE extensions to SIPTRUNK work.
thank you very much.
-SIP extgw = 100
SIPGATEWAY = 100
- Call number
73700
Area1
ARS Route List 200
Number of Digits 5
-ARS 200
-command table
carrier =0
command=I
sipgateway= 100
-ARS CONFIG:
trunk group 100
command table = 1
NPD 255
Quality + speech
-speed dialing
73700
Number= #100073700
Check Conection COS for R2 trunks and SIP trunks.
- frank
If you are using ARS for SIP, you need a command table setup.
Guilherme Arthur
Guilherme Arthur
speed dialing
73700
Number= #100073700
transit call ? i rermember an issue with incoming call to an abrv number it doesn't work even in the isdn to isdn transit call
73700
Number= #100073700
