OmniPCX Enterprise - Quick Start Guide
niko
Post by niko »
cavagnaro wrote:are u using mtcl:mtcl? It should work, if not try client client if by luck it is activated
Thanks for the answer. mtcl/mtcl worked
Now am having trouble connecting to the management tool using the browser. The java applet fails to load using any of the browsers?
Is this a known issue?
Thanks Niko
Uninstall all java version you have on your computer, then connect to the management tool. It will upload the release you need.
You can also try the standalone at
ALCATEL/TOOLS/stand-alone-client-4760i.zip
niko
Post by niko »
frank wrote:Uninstall all java version you have on your computer, then connect to the management tool. It will upload the release you need.
Thanks a lot Frank
This is a much better client that the one that I was using. At least gives me the username password. Nevertheless when I use mtcl/mtcl it gives me these errors. I thought mtcl was the accunt to use...
Can you help:(. Thanks Niko
10:14:20 AM] > Connecting to 192.168.1.12
[10:14:21 AM] > Connection Failed : Incorrect Logon
[10:14:25 AM] > Connecting to 192.168.1.12
[10:14:26 AM] > Connected to PCX. cpu_oxe.colubris.com
[10:14:39 AM] > Connection to administration server failed.
[10:14:40 AM] > cpu_oxe.colubris.com : Insufficient Rights
[10:14:48 AM] > Disconnect from PCX. cpu_oxe.colubris.com
[10:14:48 AM] > Full PCX object model is available.
When you use this, login/password is mtcl/mtcl
niko
Post by niko »
frank wrote:When you use this, login/password is mtcl/mtcl
Hi Frank
this is the combination that am using: mtcl/mtcl
Thoughts?
Thanks Niko
niko
Post by niko »
I connected finally with the omnivista client but now I get these errors when logged in as mtcl:mtcl
[6:00:53 PM] > Connected to PCX. cpu_oxe.colubris.com
[6:00:59 PM] > cpu_oxe.colubris.com : Insufficient Rights
[6:01:00 PM] > Disconnect from PCX. cpu_oxe.colubris.com
[6:01:00 PM] > Full PCX object model is available.
Thoughts? Thanks Niko
Are you connecting to a act or media gateway ? Not sure it will work on an act..
niko
Post by niko »
frank wrote:Are you connecting to a act or media gateway ? Not sure it will work on an act..
Am connecting to the Call Server Module. Should this worl? Am I in the right place to start configuring the PBX?
Thanks Niko
Is your 4760i activated? Under System in MGR 4760i and then reboot
niko
Post by niko »
cavagnaro wrote:Is your 4760i activated? Under System in MGR 4760i and then reboot
Please can you provide the steps how to check this?
I mean I can get to the System->Other System Parameters->System Parameters-?Use of 4670I
I set the value to "True" but am not sure how to save it or how to check that "true" is really ON??
Can you help?
Thanks Niko
Return to “GENERAL”
