CPU7 Bios Password
oldboy
Post by oldboy »
Just do Ctrl B Ctrl i and then hit enter and it will bring up correct menu to install from ethernet... :D
lol, don't worry happened to a lot of people.
MTCL_DUP
Post by MTCL_DUP »
I have the password but i don´t like to post it here. Maybe Alcatel change it in the next bios update :cry:
(in the bios you can force a ethernet boot)
But there is another easy way to install a new system with the PC Installer.
Just remove all partitions on the disk with a PC or Notebook.
If the hdd is clean the 4400 / OXE use ethernet boot as default.
alcatelboy
Post by alcatelboy »
unleashed ,,,,we waiting ...
not necessary to use PC for remove partition.
Use "grubboot ETHER" comman under root account.
MTCL_DUP
Post by MTCL_DUP »
ok, but what, if you don´t have any login or an uncompleted installation.
Once the pc installer hang-up and i had this problem.
But its ok. This happens 1-2 times per year at our customers.
Return to “GENERAL”
