Hi Guys
I have setup the T1 trunk but it seems to be out of service (see hors de service) when I run the trkstat command.
What should I look for?
Thanks Niko
| T R U N K S T A T E Trunk group number : 10 |
| Trunk group name : |
| Number of Trunks : 23 |
| Carrier : ANSI |
| Index : 1 2 3 4 5 6 7 8 9 10 11 12 13 |
| State : hs hs hs hs hs hs hs hs hs hs hs hs hs |
| Index : 14 15 16 17 18 19 20 21 22 23 |
| State : hs hs hs hs hs hs hs hs hs hs |
(1)cpu_oxe>
T1 Trunk State shows out of Service
niko
Hi Cavagnarocavagnaro wrote:do a trkstat of the board instead of the trunk group and see in which level it is being stopped. also check you incvisu
Incvisu:
(1)cpu_oxe> incvisu
12/09/06 22:48:38
12/09/06 22:48:58 000001I|--/--/-/---|=4:2199=A4400 Version: R6.1.1-f2.502-2-us-c80s1
12/09/06 22:49:04 000001I|--/--/-/---|=2:4351=Incoherent data: appli INITREM table ENTITY cause 0 info -1 -1 -1
12/09/06 22:49:04 000001I|--/--/-/---|=2:4351=Incoherent data: appli INITREM table ENTITY cause 1 info -1 -1 -1
12/09/06 22:51:01 000001M|--/--/-/---|=5:2009=Initialisation CPU role MAIN
12/09/06 22:51:01 000001M|--/--/-/---|=5:2019=UA_FICTIF board (coupler) commissioning
12/09/06 22:51:01 000001M|--/--/-/---|=5:2019=Z board (coupler) commissioning
12/09/06 22:51:01 000001M|--/--/-/---|=5:1367=DECT network initialization
12/09/06 22:51:01 000001M|--/--/-/---|=5:5904=Remote extension network initialization
12/09/06 22:51:01 000001M|--/--/-/---|=4:0425=PRS related activity : Interface handler started
12/09/06 22:51:01 000001M|19/02/-/---|=5:2019=INTIPA board (coupler) commissioning
12/09/06 22:51:21 000001M|01/00/-/---|=4:0740=Beginning of an INT/IP downloading @:00.80.9f.35.ec.e0 (binmg)
12/09/06 22:51:21 000001M|01/00/-/---|=5:0741=End of downloading of an INT/IPboard @:00.80.9f.35.ec.e0 (binmg)
12/09/06 22:51:37 000001M|01/00/-/---|=5:0409=The inter-ACT link over IP from(19 2) is up
12/09/06 22:51:38 000001M|01/00/-/---|=0:5857=GD/GA/INTIP/RGD: reason of reboot 2
12/09/06 22:51:43 000001M|18/00/-/---|=5:0409=The inter-ACT link over IP from(19 2) is up
12/09/06 22:51:43 000001M|--/--/-/---|=5:1567=DHCP server started
12/09/06 22:51:45 000001M|01/06/0/000|=4:2113=T2 LAPD not established still trying
12/09/06 22:51:45 000001M|--/--/-/---|=5:2141=SET resources quantity normal
12/09/06 22:51:48 000001M|--/--/-/---|=2:0276=External accounting application ???: NO RECOVERY
12/09/06 22:51:55 000001M|01/06/-/---|=4:2103=T2 access end of 75 time-out unusual
12/09/06 22:51:58 000001M|01/01/-/---|=4:0740=Beginning of an INT/IP downloading @:00.80.9f.35.e8.16 (binmg)
12/09/06 22:51:58 000001M|01/01/-/---|=5:0741=End of downloading of an INT/IPboard @:00.80.9f.35.e8.16 (binmg)
12/09/06 22:52:04 000001M|00/00/-/---|=5:5800=14 SIP trunk group put into service
12/09/06 22:52:07 000001M|01/00/-/---|=5:2019=GD board (coupler) commissioning
12/09/06 22:52:11 000001M|19/01/0/013|=3:0377=IP Phone init incident 10,(19,2),00:80:9f:58:c7:cf,2001
12/09/06 22:52:13 000001M|18/00/-/---|=5:2019=GD board (coupler) commissioning
12/09/06 22:52:13 000001M|18/01/-/---|=5:2019=4645 board (coupler) commissioning
12/09/06 22:52:15 000001M|01/06/-/---|=5:2019=DPT1 board (coupler) commissioning
12/09/06 22:52:17 000001M|01/07/-/---|=5:2019=NDDI board (coupler) commissioning
12/09/06 22:52:18 000001M|01/27/-/---|=4:2491=GPA(1,27) virtual board commissioning of the associated board GD(1,0)
12/09/06 22:52:19 000001M|--/--/-/---|=2:5410=4645 The download of the /DHS3ext/vgeva/evavg.US0 (Mu) language file failed.
12/09/06 22:52:19 000001M|01/01/-/---|=0:5857=GD/GA/INTIP/RGD: reason of reboot 2
12/09/06 22:52:21 000001M|--/--/-/---|=5:0903=VOCAL FACILITY starting link
12/09/06 22:52:21 000001M|01/06/0/000|=5:2102=T1 CCS access back to normal
12/09/06 22:52:21 000001M|01/06/0/000|=4:2113=T2 LAPD not established still trying
12/09/06 22:52:25 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
12/09/06 22:52:31 000001M|01/05/-/---|=5:2019=Z board (coupler) commissioning
12/09/06 22:52:32 000001M|19/00/0/000|=5:2862=PH: Hybrid Access (1 1 Main) is up
12/09/06 22:52:32 000001M|19/00/0/001|=5:2862=PH: Hybrid Access (1 2 Main) is up
12/09/06 22:52:33 000001M|01/02/-/---|=5:2019=UA board (coupler) commissioning
12/09/06 22:52:43 000001M|--/--/-/---|=4:4017=CSTA server: new creation 1 192.168.1.12
12/09/06 22:52:43 000001M|--/--/-/---|=2:1462=V24:45: channel configuration, operation 1, error 5
12/09/06 22:52:50 000001M|01/01/-/---|=5:2019=GA board (coupler) commissioning
12/09/06 22:52:52 000001M|01/09/-/---|=4:2491=GPA(1,9) virtual board commissioning of the associated board GA(1,1)
12/09/06 22:52:59 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
12/09/06 22:53:33 000001M|--/--/-/---|=2:1462=V24:46: channel configuration, operation 1, error 5
12/09/06 22:54:09 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
12/09/06 22:54:24 000001M|--/--/-/---|=2:1462=V24:47: channel configuration, operation 1, error 5
12/09/06 22:54:31 000001M|00/06/-/---|=5:2169=Main CPU initialization completed
12/09/06 22:55:14 000001M|--/--/-/---|=2:1462=V24:48: channel configuration, operation 1, error 5
12/09/06 22:55:19 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
12/09/06 23:06:59 000001M|01/06/-/---|=4:3580x010=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
12/09/06 23:08:09 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
12/09/06 23:09:19 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
12/09/06 23:31:29 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
12/09/06 23:32:39 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
12/09/06 23:33:49 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
12/09/06 23:55:59 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
12/09/06 23:57:09 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
12/09/06 23:58:19 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
12/09/06 23:58:54 000001M|--/--/-/---|=3:1125=External alarm: "mtcl login"
12/09/06 23:59:29 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 00:20:29 000001M|01/06/-/---|=4:3580x018=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 00:21:39 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 00:22:49 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 00:44:59 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 00:46:09 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 00:47:19 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 01:09:29 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 01:10:39 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 01:11:49 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 01:18:49 000001M|01/06/-/---|=4:3580x006=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 01:19:59 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 01:21:09 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 01:43:19 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 01:44:29 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 01:45:39 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 02:07:49 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 02:08:59 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 02:10:09 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 02:32:19 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 02:33:29 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 02:34:39 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 02:56:49 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 02:57:59 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 02:59:09 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 03:21:19 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 03:21:50 000001M|--/--/-/---|=2:0276=External accounting application ???: NO RECOVERY
13/09/06 03:22:29 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 03:23:39 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 03:45:49 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 03:46:59 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 03:48:09 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 04:10:19 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 04:11:29 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 04:12:39 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 04:19:39 000001M|01/06/-/---|=4:3580x006=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 04:20:49 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 04:21:59 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 04:44:09 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 04:45:19 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 04:46:29 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 05:08:39 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 05:09:49 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 05:10:59 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 05:33:09 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 05:34:19 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 05:35:29 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 05:57:39 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 05:58:49 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 05:59:59 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 06:22:10 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 06:23:20 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 06:24:30 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 06:46:40 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 06:47:50 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 06:49:00 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 07:11:10 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 07:12:20 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 07:13:30 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 07:20:30 000001M|01/06/-/---|=4:3580x006=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 07:21:40 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 07:22:50 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 07:45:00 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 07:46:10 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 07:47:20 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 07:50:50 000001M|01/06/-/---|=4:3580x003=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 07:51:50 000001M|--/--/-/---|=2:0276=External accounting application ???: NO RECOVERY
13/09/06 07:52:00 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 07:53:10 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 08:09:30 000001M|01/06/-/---|=4:3580x014=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 08:10:40 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 08:11:50 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 08:34:00 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 08:35:10 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 08:36:20 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 08:58:30 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 08:59:40 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 09:00:50 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 09:23:00 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 09:24:10 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 09:25:20 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 09:47:30 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 09:48:40 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 09:49:50 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 10:12:00 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 10:13:10 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 10:14:20 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 10:21:20 000001M|01/06/-/---|=4:3580x006=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 10:22:30 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 10:23:40 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 10:45:50 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 10:47:00 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 10:48:10 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 11:10:20 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 11:11:30 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 11:12:40 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 11:34:50 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 11:36:00 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 11:37:10 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 11:59:20 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 12:00:30 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 12:01:41 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 12:21:31 000001M|01/06/-/---|=4:3580x017=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 12:21:51 000001M|--/--/-/---|=2:0276=External accounting application ???: NO RECOVERY
13/09/06 12:22:41 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 12:23:51 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 12:25:01 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 12:26:11 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 12:48:21 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 12:49:31 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 12:50:41 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 13:12:51 000001M|01/06/-/---|=4:3580x019=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 13:13:25 000001M|--/--/-/---|=3:1125=External alarm: "mtcl login"
13/09/06 13:14:01 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
13/09/06 13:15:11 000001M|01/06/-/---|=4:3580=remove TEI: mod ISDN UNSUCCESSFULL_RETRANS_OF_SABME (0) really: 0 info: 0
(1)cpu_oxe>
| T R U N K S T A T E - PRA T Coupler Crystal_nbr = 1 |
| IN SERVICE Coupler Nbr = 6 |
| Type : T1 CCS Access 0 : ENABLED level2 : ATT_CONNECT2 |
| B channel rate : 64K |
| Trunk Grp 10 10 10 10 10 10 10 10 10 10 10 10 |
| Channel 1 2 3 4 5 6 7 8 9 10 11 12 |
| State F F F F F F F F F F F F |
| Trunk Grp 10 10 10 10 10 10 10 10 10 10 10 |
| Channel 13 14 15 16 17 18 19 20 21 22 23 |
| State F F F F F F F F F F F |
| Trunk Grp |
| Channel |
| State |
| ALARM COUNTERS |
| LMFA | RAI | LFA | AIS | LOS | MIC_LOOP |
| 0 | 23 | 8 | 0 | 6 | 0 |
| LMFA : Loss of Multi Frame Alignement | RAI : Remote Alarm Indication |
| LFA : Loss of Frame Alignement | AIS : Alarm Indication signal |
| LOS : Loss Of Signal | |
(1)cpu_oxe>
- frank
For the error that you have in the list, do a tabrasfo 1 20. If you have anything in this table, go under the phone feature class of service and turn off Auto.call back satell.trk grp then you will have to reboot if it's a simple CPU or do a double bascule.
Regarding your T1, it looks like you don't have the D channel. Talk with the CO.
niko
Frank, thanks.frank wrote:For the error that you have in the list, do a tabrasfo 1 20. If you have anything in this table, go under the phone feature class of service and turn off Auto.call back satell.trk grp then you will have to reboot if it's a simple CPU or do a double bascule.
Patch identification: 2
Dynamic patch identification: none
Country: us
Cpu: c80s1
ACD VERSION
release : 6
bug_fixing : 1
protocol_id : 90
version_dy_hr_stat : 11
(1)cpu_oxe> tabrasfo 1 20
nbrasfo_min 1 nbrasfo_max 20
idx_rasfolib = 1
| nulog | fais | teqt | jeqt | demande | demandeur | chain |
[ 1] | 0 | -1 | 0 | 0 | | | 2 |
[ 2] | 0 | -1 | 0 | 0 | | | 3 |
[ 3] | 0 | -1 | 0 | 0 | | | 4 |
[ 4] | 0 | -1 | 0 | 0 | | | 5 |
[ 5] | 0 | -1 | 0 | 0 | | | 6 |
[ 6] | 0 | -1 | 0 | 0 | | | 7 |
[ 7] | 0 | -1 | 0 | 0 | | | 8 |
[ 8] | 0 | -1 | 0 | 0 | | | 9 |
[ 9] | 0 | -1 | 0 | 0 | | | 10 |
[ 10] | 0 | -1 | 0 | 0 | | | 11 |
[ 11] | 0 | -1 | 0 | 0 | | | 12 |
[ 12] | 0 | -1 | 0 | 0 | | | 13 |
[ 13] | 0 | -1 | 0 | 0 | | | 14 |
[ 14] | 0 | -1 | 0 | 0 | | | 15 |
[ 15] | 0 | -1 | 0 | 0 | | | 16 |
[ 16] | 0 | -1 | 0 | 0 | | | 17 |
[ 17] | 0 | -1 | 0 | 0 | | | 18 |
[ 18] | 0 | -1 | 0 | 0 | | | 19 |
[ 19] | 0 | -1 | 0 | 0 | | | 20 |
[ 20] | 0 | -1 | 0 | 0 | | | 21 |
(1)cpu_oxe>
This is what I got. Where do you find this "feature class of service"
Merci beaucoup!
niko
niko wrote:Frank, thanks.frank wrote:For the error that you have in the list, do a tabrasfo 1 20. If you have anything in this table, go under the phone feature class of service and turn off Auto.call back satell.trk grp then you will have to reboot if it's a simple CPU or do a double bascule.
Country: us
Cpu: c80s1
ACD VERSION
release : 6
bug_fixing : 1
protocol_id : 90
idx_rasfolib = 1
(1)cpu_oxe>
This is what I got...
Merci beaucoup!
niko
Thank you.frank wrote:Class of service / Phone feature COS
I believe it's in one of the first 3 pages. But I am not sure that this is your problem, since your call back table seems to be clear.. maybe it's name presentation ? Where is this T1 connected to ? Another PBX or CO ?
The T1 is attached to the existing Nortel Meridian PBX.
alurfe
niko
