Dear all,
i want delete one link bus access,
i have disable before in X25 configuration,
buat i can't delete the error always showing :
ÚÄDelete: Link Bus AccessÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ¿
³ ³
³ Node Number (reserved) : 1 ³
³ Instance (reserved) : 1 ³
³ Link Name : OFJ-GU ³
³ Physical Address : 0-3-0 ³
³ ³
ÀÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÙ
press F1
ÚÄError:ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ¿
³ ³
³ Press CANCEL to remove this window ³
³ ³
³ processing Failure ³
³ OBJECT -1: Physical Address: access cluster null (remanent) ³
³ ³
ÀÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÙ
please advice how to solve .
thanks for help.
best Regard
Irham
Hi! - I moved the server over the week end to handle the daily incoming connections (about 200K/day) but it looks like I aimed too low for the resources. I'm going to have to move this server (hopefully for the last time) this week. I'm sorry for the interruption.
cannot delete link bus
Re: cannot delete link bus
To delete any links you have to do it backwards from the way you created it. If this doesn't work then try to run these commands before you do it:
1) checkdb
2) fichges force_recover_dico (in case checkdb says that your database is corrupted)
BTW, I still believe that you have not disabled the right X.25 cluster. It's very unlikely that it is a database issue.
1) checkdb
Was it a database issue? We will never know since it seems I replied to a 2006 post. :-S
Note: If it was a DB issue, you should not correct your database. There are only a few people who are allowed do these corrections because it might create errors in associated tables. Even though I know how to correct the DB errors, I still need to have my corrections checked for regressions afterwards.
If you have CCD on the installation. Do not touch the database and open a ticket with ALU.
