we have recently installed Omnivista 4760 ver. 4.0 and there are no Events collected in Alarms application.
The company who installed Omnivista claims that the reason for it might be that we installed it on Windows 2003 server running on Virtual Server 2005 and Alcatel doesn't say that Virtual Server is supported.
But in my opinion it shouldn't do any difference if it's Virtual server or not, anyway it's Windows 2003 server.
Could be some other reason for it? Maybe there is something not properly configured (at the beginning there were also no alarms collected by I changed Alarm reception mode and now it's collected).?
BR,
syra
Events missing in Omnivista
wizzy
syra
settings for event reception
But what should be set in 4760 and PCX in order to receive events?
wizzy
syra
setting evvents
I have parameter "Alarm reception mode" set to Permanent IP connectivity.
And alarms are collected but events no.
Is that all which should be set up?
syra
events
It's release 7.0 f4.401.
And I run incvisu and all events and alarms are displayed. And strange thing, after that I logged on to Omnivista and checked Events tab and... all the events are displayed there now!
I have no idea if this is caused by running incvisu or it's connected with some my other actions. Anyway it's working now.
Thanks for all your replies and help.
