ISDN trace in OXO
steve
ISDN trace in OXO
Post by steve »
hello,
Does anybody have info about the T0/T2 trace through the OXO v24 config port ? Is it possiable or not ?
Unfortunately it is not possible on OXO :? The only possibility is to talk to your T0/T2 subscriber and ask him what he is sending you and what he needs you to send, and then to configure OXO like that. Maybe if your provider is nice enough he can put a trace on you and give you feed-back when you make tests. :roll: Good Luck!
Return to “MAIN”
