Installation of 4760
unifoo
Post by unifoo »
Has anyone an idea?
Wanna install the 4760 on a normal w2k machine, but every time I start the installation there comes a prompt "wrong pc-configuration" did the 4760 setup check the hardware?
Does it say wrong PC configuration, or wrong NETWORK configuration ?
Usually, it's because you did not add the local host name in the hosts file..
goldy
Post by goldy »
also make sure there the qualified domain name is set for the machine, eg yourserver.company.com :wink:
Return to “OmniVista 4760”
