Can I mix IBS and RBS for one area?
tony.alu
Post by tony.alu »
Dear friends,
I have a doubt in dect installation.
Whether I can use IBS ans RBS basestation for one area.
I mean is it possible to have the hand over between IBS base station to RBS base station?
Please any body can clear my doubt.
With regards
Tony
leo
Post by leo »
Hi Tony,
You can install IBS and RBS in a system but the radio coverage of two domains must not overlap otherwise you can have the Campus effect. Moreover the handover does not operate between RBS and IBS.
Leo
mothinx
Post by mothinx »
Switching RBS to IBS area will make your call "on hold" during the process.
tony.alu
Post by tony.alu »
Hi friends,
Thanks for your valuable information.
But whether one dect phone can access IBS and RBS.
If I gave the same pari number of RBS to IBS also, can it works.
I am facing a problem that I hand over from IBS to RBS is not happening. It is not even going to hold.
Can please brief about the configuration. ?
With regards
Dileep Kumar
Eliott
Post by Eliott »
It's not possible to synchronize the IBS and the RBS clocks? => Not possible.
Percival
Post by Percival »
Remove the soundcard and use the on-board one for a while. It might be your iissue.
Also, make sure that your on-board sound is disabled in the BIOS if you are using the soundcard.
murraya
Post by murraya »
???? soundcard?
are you sure you ment to reply to this post Perciival?
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Return to “PWT/DECT System”
