MyTeamWork Confrence call
lamhotPS
Hi All,
i already set up MyTeamWork Server 6.0 with OXE 9.0,problem is when the leader try to do confrence call which first ringing should the leader's SIP phone ( using eye beam ) but it's not because another phone is ringing ( other phone set ).
can anyone help,please?
thank's before.
thank's before.
lamhotPS
Hi Cav,
thank you..
Tue Feb 9 11:13:12 WIT 2010
| SIP Gateway |
Machin name : node000001
IP Address : 10.88.88.5
Subnetwork number : 15
SIP Trunk Group : 1
DNS Informations :
DNS local domain name :
| Trusted IP Address List |
Trusted IP Address 1 : 10.88.88.7
| Quaranted IP Address List |
motortrace (v5.2.0) verbosity = 0037b524
sipmotor trace-level set c (data dump).
Proxy parameters.
initial_timeout 500
timer_t2 4000
recursion 0
min_auth_method 2 NONE=0 DIGEST=2
auth_realm 10.88.88.5
sipConnectionDuration 5000 not used
onlyAuthIncomingCalls 0
quarantine and trusted addresses:
nb_msg_by_period 25
period 3
framework_quarantine_period 1800
Gateway parameters.
url_install 10.88.88.5
url_gw
url_hostname node000001
num_ss_reseau 15
num_faisc 1
proxy_address not used
DNS_localDomName
DNS_type 0 dnsa=0, dnssrv=1
DNS_primaire Unused
DNS_secondaire Unused
prack_required 0
out_proxy 0 AUCUN=0 INTEGRE=1 EXTERNE=2
proxy_port 5060
proxy_transport 1 TCP=0 UDP=1
sipSubsMinDuration 1800
sipSubsMaxDuration 86400
sipSessionTimer 1800
sipMinSessionTimer 900
SessionTimerMethod 0 re-invite=0, update=1
sipCac 0
SDP_in_180 1
sip_info_enable 0
payload 97
seplos 1
Registrar parameters.
declared_sets 0
min_expiry_date 1800
max_expiry_date 86400
CPU address.
physical local 10.88.88.5
physical twin
role Main 10.88.88.5
Licenses parameter.
nb max licences 70
thank you..
| SIP Gateway |
SIP Trunk Group : 1
DNS Informations :
Proxy parameters.
initial_timeout 500
timer_t2 4000
recursion 0
nb_msg_by_period 25
period 3
Gateway parameters.
url_gw
num_ss_reseau 15
num_faisc 1
DNS_localDomName
DNS_primaire Unused
prack_required 0
proxy_port 5060
sipCac 0
SDP_in_180 1
sip_info_enable 0
payload 97
seplos 1
declared_sets 0
CPU address.
physical twin
Licenses parameter.
nb max licences 70
lamhotPS
10/02/10 14:29:24
10/02/10 14:29:43 000001I|---/--/-/---|=4:2199=A4400 Version : R9.0-h1.301-24-ii
-c80s1
10/02/10 14:29:53 000001I|---/--/-/---|=2:4351=Incoherent data: appli INITREM ta
ble ENTITY cause 0 info -1 -1 -1
ble ENTITY cause 1 info -1 -1 -1
ble ENTITY cause 2 info -1 -1 -1
10/02/10 14:31:34 000001I|---/--/-/---|=2:1542=Partition 6 is 79 per cent full (
resource 2).
10/02/10 14:31:35 000001M|---/--/-/---|=5:2009=Initialisation CPU role MAIN
10/02/10 14:31:35 000001M|---/--/-/---|=5:2019=UA_FICTIF coupler commissioning
10/02/10 14:31:35 000001M|---/--/-/---|=5:2019=Z coupler commissioning
10/02/10 14:31:35 000001M|---/--/-/---|=5:1367=DECT network initialization
10/02/10 14:31:35 000001M|---/--/-/---|=5:5904=Remote extension network initiali
zation
10/02/10 14:31:35 000001M|---/--/-/---|=4:0425=PRS related activity : Interface
handler started
10/02/10 14:31:35 000001M|019/01/-/---|=5:2019=INTIPA coupler commissioning
10/02/10 14:31:48 000001M|002/00/-/---|=5:0409=The inter-ACT link over IP from (
19 1) is up
10/02/10 14:31:48 000001M|002/00/-/---|=0:5857=GD/GA/INTIP/RGD: reason of reboot
21
10/02/10 14:31:48 000001M|002/00/-/---|=2:5865=GD: Delivery file checking failed
(binmg) 1
10/02/10 14:31:48 000001M|002/00/-/---|=0:5859=MG/RGD: download status 1
10/02/10 14:32:05 000001M|002/01/-/---|=4:0740=Beginning of an INT/IP downloadin
g @:00.80.9f.83.95.e0 (binmg)
10/02/10 14:32:05 000001M|002/01/-/---|=5:0741=End of downloading of an INT/IP b
oard @:00.80.9f.83.95.e0 (binmg)
10/02/10 14:32:07 000001M|002/01/-/---|=4:0740=Beginning of an INT/IP downloadin
10/02/10 14:32:07 000001M|002/01/-/---|=5:0741=End of downloading of an INT/IP b
10/02/10 14:32:09 000001M|001/00/-/---|=4:2615=Voice Guide channel lack for VG N
o 5
10/02/10 14:32:17 000001M|---/--/-/---|=4:4017=CSTA server : new creation 1 10.0
.2.74
10/02/10 14:32:18 000001M|002/00/-/---|=5:2019=GD coupler commissioning
10/02/10 14:32:19 000001M|---/--/-/---|=4:4017=CSTA server : new creation 2 10.8
8.88.6
10/02/10 14:32:23 000001M|000/00/-/---|=5:5800=1 SIP trunk group put into servic
e
10/02/10 14:32:33 000001M|002/01/-/---|=0:5857=GD/GA/INTIP/RGD: reason of reboot
2
10/02/10 14:32:33 000001M|002/27/-/---|=4:2491=GPA(2,27) virtual coupler commiss
ioning of the associated coupler GD(2,0)
10/02/10 14:32:53 000001M|---/--/-/---|=2:1462=V24:45: chanel configuration, ope
ration 1, error 5
10/02/10 14:33:04 000001M|002/01/-/---|=5:2019=GA coupler commissioning
10/02/10 14:33:14 000001M|002/09/-/---|=4:2491=GPA(2,9) virtual coupler commissi
oning of the associated coupler GA(2,1)
10/02/10 14:33:31 000001M|002/03/0/000|=4:2113=T2 lapD not established still try
ing
10/02/10 14:33:31 000001M|002/06/0/000|=4:2113=T2 lapD not established still try
ing
10/02/10 14:33:31 000001M|002/04/0/000|=4:2113=T2 lapD not established still try
ing
10/02/10 14:33:37 000001M|---/--/-/---|=3:1125=external alarm : "mtcl login"
10/02/10 14:33:41 000001M|002/03/0/000|=5:2102=T2 access back to normal
10/02/10 14:33:41 000001M|002/03/0/000|=4:2113=T2 lapD not established still try
ing
10/02/10 14:33:41 000001M|002/04/0/000|=5:2102=T2 access back to normal
10/02/10 14:33:41 000001M|002/04/0/000|=4:2113=T2 lapD not established still try
ing
10/02/10 14:33:41 000001M|002/03/0/000|=5:0311=T2 Dlap Established
10/02/10 14:33:41 000001M|002/06/0/000|=5:2102=T2 access back to normal
10/02/10 14:33:41 000001M|002/06/0/000|=4:2113=T2 lapD not established still try
ing
10/02/10 14:33:41 000001M|002/04/0/000|=5:0311=T2 Dlap Established
10/02/10 14:33:42 000001M|002/06/0/000|=5:0311=T2 Dlap Established
10/02/10 14:33:43 000001M|---/--/-/---|=2:1462=V24:46: chanel configuration, ope
ration 1, error 5
10/02/10 14:34:01 000001M|002/03/-/---|=5:2019=PRA coupler commissioning
10/02/10 14:34:01 000001M|002/06/-/---|=5:2019=PRA coupler commissioning
10/02/10 14:34:01 000001M|002/04/-/---|=5:2019=PRA coupler commissioning
10/02/10 14:34:18 000001M|002/07/-/---|=2:2457=PRA coupler (2,7) not initalized
yet
10/02/10 14:34:34 000001M|---/--/-/---|=2:1462=V24:47: chanel configuration, ope
ration 1, error 5
10/02/10 14:35:04 000001M|000/06/-/---|=5:2169=Main CPU initialization completed
10/02/10 14:35:24 000001M|---/--/-/---|=2:1462=V24:48: chanel configuration, ope
ration 1, error 5
10/02/10 14:35:45 000001M|---/--/-/---|=2:5815=Major failure in SIP component
10/02/10 14:35:45 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
10/02/10 14:35:46 000001M|---/--/-/---|=2:5815=Major failure in SIP component
10/02/10 14:35:46 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
10/02/10 14:35:47 000001M|---/--/-/---|=2:5815=Major failure in SIP component
10/02/10 14:35:47 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
10/02/10 14:35:49 000001M|---/--/-/---|=2:5815=Major failure in SIP component
10/02/10 14:35:49 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
10/02/10 14:35:53 000001M|---/--/-/---|=2:5815=Major failure in SIP component
10/02/10 14:35:53 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
10/02/10 14:35:57 000001M|---/--/-/---|=2:5815=Major failure in SIP component
10/02/10 14:35:57 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
10/02/10 14:36:01 000001M|---/--/-/---|=2:5815=Major failure in SIP component
10/02/10 14:36:01 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
10/02/10 14:36:05 000001M|---/--/-/---|=2:5815=Major failure in SIP component
10/02/10 14:36:05 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
10/02/10 14:36:09 000001M|---/--/-/---|=2:5815=Major failure in SIP component
10/02/10 14:36:09 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
10/02/10 14:36:13 000001M|---/--/-/---|=2:5815=Major failure in SIP component
10/02/10 14:36:13 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
10/02/10 14:36:29 000001M|019/00/0/001|=3:1307=MCDU in distri tab entity 0, col
Night , line 4 incorrect or missing
10/02/10 14:36:59 000001M|019/00/0/001|=3:1307=MCDU in distri tab entity 0, col
10/02/10 14:50:02 000001M|---/--/-/---|=3:1125=external alarm : "mtcl login"
10/02/10 14:52:18 000001M|---/--/-/---|=4:4018=CSTA server : 1 connection closed
10/02/10 14:54:03 000001M|000/00/-/---|=5:5800=1 SIP trunk group put into servic
e
10/02/10 15:18:04 000001M|---/--/-/---|=2:5815=Major failure in SIP component
10/02/10 15:31:41 000001M|---/--/-/---|=2:1542=Partition 6 is 79 per cent full (
resource 2).
10/02/10 15:42:04 000001M|---/--/-/---|=2:5815=Major failure in SIP component
10/02/10 16:06:04 000001M|---/--/-/---|=2:5815=Major failure in SIP component
10/02/10 16:07:40 000001M|---/--/-/---|=3:1125=external alarm : "mtcl login"
-c80s1
resource 2).
zation
handler started
19 1) is up
21
(binmg) 1
o 5
.2.74
8.88.6
e
2
ration 1, error 5
ing
ing
ing
ing
ing
ing
ration 1, error 5
yet
ration 1, error 5
ration 1, error 5
e
resource 2).
lamhotPS
cavagnaro wrote:I meant the SIP logs of the call you describe. Please do a
sipmotor=3
traced
and indicate the desired scenario and what you get.
Also please post a screenshot of the configuration of the phones for that user under TW admin page.
Hi Cav,
PBX Ip : 10.88.88.5
Mytw Server ip : 10.88.88.7
and here's SIP trace i attach with.
