OXO Dect-GAP Handsets?
OXO-Man
Post by OXO-Man »
do you have any suggestions, which Dect-GAP Mobiles work proberly with the OXO (alle releases)?
Has anybody a list of compatible Mobile´s (e.g. Siemens Gigaset xx ....)?
In the past we have had some problems with the new Siemens Sxx-serie..
Thanks for help!
Best regards
Thomas
henk1964
Post by henk1964 »
Siemens E45 works well
Siemens SL1 Profesional is good.
Do NOT use the normal SL1, only the pro version works well.
Both have limited battery life so do not use them if you call more then 4 hours a day ;-)
Avi1
Post by Avi1 »
We had also problems with the SL1 not only with the battery but also with the ringing when a call comes in or sometimes it disconnects itselfe from the OXO.
And we have very much problems with the new C45 !
At the moment we sell the S45, C32/C320 and the SL1 Pro.
Martijn
Post by Martijn »
We don't install any siemens handsets on a Oxo at this moment to many different problems at this time.
Only the old ones works ok.
laroth
Gigasets logs off and won't ring when called.
Post by laroth »
We have also had trouble with Gigasets SL1 , C45 that seems to work fine but will not ring when called after a while, or power loss on pbx.
Also miss the "missed call log" on GAP handset, but PimPhony has a nice log. I wasn't aware over that there where different versions of the SL1 handset.
KIRK handsets have a nice sound and are solid but expensive, like the Mobile 100/200.
ranx
Post by ranx »
We're also having trouble with SL1, on 4400 R3.0.
From time to time it is just not receiving calls anymore or the PABX thinks it's busy all the time. Remedy is to dectrm, then delete from system, re-create it and then dectinston. That's what I do if I have just a few phones with the problem. If it's more, restarting the Node which handles DECT sets helps. In my case, I reset it (doing mastercopy of database before) about once a month...
Furthermore, SL1 colour is slick, real dandy phone, but quality is :roll:
especially in industrial environment. I've found many sets with mould inside, and lots with problems appearing out of nowhere.
If anyone has some good troubleshooting/repairing tips for SL1, please post it :-)
stepanek
Re: OXO Dect-GAP Handsets?
Post by stepanek »
how did you configure the e45 to forwad calls to other phones using the flash-key?
Return to “MAIN”
