Accounting over Ethernet
sera544
Post by sera544 »
Hi all,
I need some info abt this above topic, i do have a license in OXE for accounting over ethernet and i finished the configuration, now my software developers when they are trying to connect the client to oxe, we put the IP address & port number 2533, i get nothing on the screen.
But from OXE if i run the command eaccclt -cpu xx.xx.xx.xx i can see the smdr tickets.
if anybody done this before can u plz share the info to me..thanks in advance..
cheers
In internal application / accounting/ internal accounting/ management - output on ethernet - you hav dialog description. You need to sends the message "INIT_REQ": 00H 02H 00H 00H (for test I use input with Alt+numeric key pad - f.e. Alt+000 for 00H)
To check that the remote machine is present, the PCX sends test frames every 30 seconds.
The PCX sends the message "TEST_REQ": 00H 08H "TEST_REQ"
The external machine must repond with the message "TEST_RSP" : 00H 08H "TEST_RSP"
If two "TEST_REQ" messages remain unanswered, the PCX considers that the external machine can no longer be reached. It closes the connection and releases associated resources.
From R9.1 doc. Open connection with port 2533,
Identifying CPU role:
The external application sends the message: 00H 01H 53H ("S" message used to select the SvTSE accounting server).
The Alcatel-Lucent OmniPCX Enterprise CS responds with the message: 00H 01H 50H if the CPU is the Main CPU.
When the CPU is duplicated, the external application must always addresses the Main CPU.
Server initialization:
The external application sends the message INIT_REQ: 00H 02H 00H 00H
The Alcatel-Lucent OmniPCX Enterprise CS responds with the message INIT_RSP: 03H 04H
Maintaining dialog connection
To check that the remote application is present, the Alcatel-Lucent OmniPCX Enterprise CS sends test frames every 30 seconds.
The Alcatel-Lucent OmniPCX Enterprise CS sends the message TEST_REQ: 54H 45H 53H 54H 5FH 52H 45H 51H
The external application responds with the messageTEST_RSP : 00H 08H 54H 45H 53H 54H 5FH 52H 53H 50H
If two TEST_REQ messages remain unanswered, the Alcatel-Lucent OmniPCX Enterprise CS considers that the external application can no longer be reached. It closes the connection and releases associated resources. The external application must reinitiates the dialog by sending the "S" message.
sera544
Post by sera544 »
Hi vad,
Thanks for your reply..for dialog intiation has to be done by TCP client automatically, i download the tcp client when i am trying to send the msg it gives me error i thing its from the software, is there anyway we can do the test with tcp client ...i just want to show it to the guyz string is coming out from the oxe in tcp client..
You can open usual telnet (with port 2533) - send 00H 01H 53H, after send 00H 02H 00H 00H.
for 00H - press Alt key and dial 000 (from numeric keyboard), release Alt. For 53H - press Alt key and dial 083 (from numeric keyboard), release Alt. for 01 - 001, for 02 - 002.
After you have 30 or 60 sec for receiving on line tickets.
umit
Re: Accounting over Ethernet
Post by umit »
hi,
when I send 00H 01H 53H I get 00H 01H 50H, I send 00H 02H 00H 00H and I get 03H 04H. TEST_REQ and TEST_RSP are sent and received without problem and test messages are periodically sent and received without problem.
The problem is; the pbx begins to send 01H 00H 01H 00H 48H 00H 00H.. total 772 bytes - all remaining bytes are 00H
I send 00H 02H 00H 03H as TICKET_ACK, but there is no other message received other than TEST_REQ.
What might be the problem?
ether
Post by ether »
How many simultaneous pc/clients can connect to this?
alex
Post by alex »
ether wrote: 29 Feb 2024 03:53 How many simultaneous pc/clients can connect to this?
Only one client connection is possible. It is written somewhere in the system docs.
Next client connected would overtake netaccess connection.
ether
Post by ether »
alex wrote: 01 Mar 2024 02:16
Thank you alex.
In docs only I can find to disconnect external app first when connecting eaccclt.
Return to “MAIN”
