Upgrade of 4635 VM
rholubec
Upgrade of 4635 VM
Post by rholubec »
Has anyone completed an upgrade of a 4635 VM system?
I have a doc from Alcatel that goes through the procedure, although two of the steps are confusing:
7) Modify the bootptab file in order to fill the parameter HOSTNAME_PREFIX with the A4635 name managed in the above
item 5.
Example
HOSTNAME_PREFIX=a4635:\
8) Modify the bootptab file in order to fill the parameter FIRST_FREE_IP_ADDR with the A4635 IP address name
managed in the above item 5.
Example
FIRST_FREE_IP_ADDR=10.10.10.20:
Are these the bootp files on the PC server, VM card or the 4400???
Hi !
The bootptab is on your laptop.
Usually, it is in your c:/etc/ directory, once you install the bootpd / ftpd on it (from alcatel) so you can upload release previous to 5.0 (not using the pc install) and the voicemail
goldy
Post by goldy »
there should be an installation procedure delivered in the s/w. It should explain all the steps required, as Frank saya, it is different to the Lx & uses another method to install. It is basically a bootp/tftp/rcatd program that runs on a win pc to install the files for the 4635.
Let me know if you are still having troubles :)
It's kind of rusty, but check this.. it might help you for a good start.. If not, give me a call, hopefully you still have my phone # :-)
http://alcatel.gadot.net/ALCATEL/TOOLS/4635_loading.doc
kenzo_DUP
4636 VP5 loading software document
Post by kenzo_DUP »
Hi anyone can sent me the document for 4636 VP5 loading software document from a fresh hardisk?
whistler_DUP
Post by whistler_DUP »
if you have software cd-rom for 4635, complete documentation can be found there... file name install.pdf. example of bootptab file, that always work:
a4635.dummy:\
:ht=ethernet:\
:hd=/a4635:\
:bf=kernel.ram:\
:vm=rfc1048:\
:hn:\
:bs=auto:\
:T129="C:":
DYNAMIC_IP.dummy:\
:tc=a4635.dummy:\
:HOSTNAME_PREFIX=vps:\
:NB_FREE_IP_ADDR=10:\
:FIRST_FREE_IP_ADDR=146.112.132.194:
just put content of cd-rom in folder c:\a4635 set ip-addres for 4635 and start bootpd
Muhammad alam
Re: Upgrade of 4635 VM
Post by Muhammad alam »
Sir kindly attach the bootptab file. I have not old release version
. Plz plz
whistler
Post by whistler »
this is simple text file. Example of it full content - in message above.
Muhammad alam
It is not working. Serching server. And kindly tell me that in etc folder which more file or folder required. And kindly attach the bootptab file plz. May be i m doing mistake somewhere
Muhammad alam
First time i m doing this and dont know the first ip address and where i will give the ip for vpm35 plz teach me in a simplest way thanks
Return to “Voicemail (46x5)”
