No Logins of MyPhone possible: "Licenced number of user
ebolar
Post by ebolar »
Hello All,
Some users have the following problems ( OXE 7.1 with OTUC Server ):
Sometimes a user gets the error message "The licence associated with this user is not correct. Licensed number of users already reached (-4,132)"
We have enough licenses purchased, I don´t understand this ...
I know, that hardphones and softphones counts in the same way. I only setup MyPhone users, no MyAssistant users, so it should not be a problem.
It seems for me, that some dead connections causes the error ....
Any ideas?
Where do you see this error? On OTUC? If so, where exactly?
On OTUC the license is counted by user created, not by user online.
Go to http://otuc:8083/webAdmin and then to license section, launch an audit and verify everything is ok.
ebolar
Post by ebolar »
Thanks for the fast reply!
The error occurs at client (MyPhone) side, when trying to connect to the OTUC Server.
I launched an audit, everything seems to be ok. All stats are green!
Here the licenses:
License Name Remaining Maximum Status
My Phone
5 ( remaining )
40 ( Maximum )
My Assistant
5
5
My Messaging
5
5
SoftPhone 4980
5
40
Dash Board
40
40
My Phone (web service)
5
40
And the OXE licenses? You need also licenses on that side.
Lock 117 value? (4980 SoftPhone)
Lock 129 value? (MySoftPhone)
Lock 313 value? (eCC Gateway)
Can you please tell if you are using Websoftphone only or WebIp Softphone?
ebolar
Post by ebolar »
How can I check the licenses on the OXE side?
We are only using IPSoftphones (4980 Client ), no WebPhones.
The WebPhones are created by Default, when I choose "Thick Client", aren´t they?
Nevertheless, at creation time I never got an error....
Run spadmin option 2 on your OXE, if you are not the OXE manager ask to your administrator to do it.
Maybe that is the problem, that you doesn't have the licenses on the OXE.
ebolar
Post by ebolar »
The output is:
seems to have 35 licensesfor SoftPhones, not 40 !??!
But what about ECC? There is a value of 2. What does this mean?
-------------------snip-------------------
Alcatel OmniPCX Enterprise
# The role of the CPU is MAIN
Application software identity
R7.1-f5.401-7-ge-c80s1
DLL version = 0110
File version = 1
OXE version = 0110
Soft Key =
Cpu Id 0 =
Your System CPU-Id:
System CPU-Id found
Handle 4760 =
Timestamp :
Tue Dec 5 09:14:28 2006
SP_OPS_Version = 00000
1 Group Telephony = 9999
2 M Phonebook users = 19/ 80
4 Hotel guest sets = 0
5 Multilangual voice prompts = 0
6 Hotel: AHL on V24 = 0
9 PSTN B channel = 9999
10 Voice Guide = 1
12 DISA = 0
13 ECS Engine = 9999
14 Integrated metering report = 0
19 Corporate netw. (ABC,ABCVPN,ISVPN) = 0
20 Automated attendant = 0
21 Nb of VPS ports = 0
29 DECT/PWT Engine = 0
38 Infocenter link = 0
39 Performance = 0
40 Real Time Incidents = 0
41 DECT register = 80
42 Accounting users = 80
44 4059 SBC = 0
45 4059 BLF = 0
46 Fax server ABC-A link = 0
47 Alarms = 0
49 Directory = 0
50 Configuration = 80
51 Real Time Metering on V24 = 80
52 4635 Basic Package = 0
56 4635 Networking OctelNet = 0
57 4635 Fax manager = 0
58 4635 Call manager = 0
59 4635 Hotel manager = 0
60 4635 Nb of ports = 0
61 4635 Nb of hours = 0
62 4635 Nb of languages = 0
63 4635 Attendant manager = 0
65 4635 Recording manager = 0
66 4635 Networking AMIS = 0
75 Networking hospital = 1
76 M CCD Agents = 0
77 CCS mono-site = 0
78 CRI call record interface = 0
79 ISVPN = 0
80 VPN = 0
81 Meet me conf. between 29 parties = 0
82 Nb of DECT terminals = 0
83 Flow Metering on Ethernet = 80
84 4635 users = 0
86 Automatic directory pop-up = 0
87 Beta Test = 0
89 Notification server = 0
90 M Roaming DECT/PWT = 0/ 0
91 Voice guide record from Reflexes = 0
94 WMI Workforce manager interface = 0
97 VPS users = 9999
98 Accounting for local calls = 0
99 Accounting for ABC calls = 0
100 CSTA profile = 2
101 CSTA monitoring requests = 10
102 CCS multi-site = 0
103 Real Time Interface = 0
105 Compressed calls = 0
106 Transfix Access X24/V36 = 9999
107 4635 Visual messenger = 0
109 4635 IP Octel Networking = 0
110 4635 Global message redundancy = 0
111 Ubiquity = 0
113 CSTA pilots monitoring = 0
114 TSAPI server = 0
115 CCA softphone = 0
116 ECC My Softphone (4980 Std) = 5000
117 M ECC 4980 Option (4980 Adv) = 35/5000
119 4980 nomadic logged = 5000
121 CLIP on VPS = 0
122 ACAPI via CMIP = 80
123 CSTA IVR ports monitored = 0
125 CCweb Agents = 0
126 Hotel AHL link = 0
127 M Encryption DECT/PWT users = 0
128 4615 ports = 0
129 M ECC My Softphone (4980 Grp) = 35/5000
130 CSTA voice recording type = 0
131 Remote LIO = 0
132 IP-Trunk = 0
133 Mastered conference = 0
134 Multi-tenant = 0
135 G729A Server = 0
136 Priority = 0
137 Call restriction = 0
138 IP Clients = 20
143 TAPI premium server = 0
145 CSTA Recording B channel = 0
146 PWT mobility (UTAM) = 0
148 IP Call Server = 1
151 4635 VPIM = 0
152 Ith radio = 0
153 SNMP Trap = 1
154 Additional S0 features = 0
155 Additional safety features = 0
156 Ith = 0
157 CCA nomadic = 0
158 CSTA By-pass = 500
160 CCemail Agents = 0
161 CCoutbound Agents = 0
162 CCoutpredial Agents = 0
164 CSTA Record networked = 0
165 OmniPCX Enterprise release = 36
166 4980 multi device = 5000
167 ACR data base read = 0
168 Nb of HPOV node = 0
169 Voice detection channels = 0
173 M Advanced Reflexes users = 4/ 80
174 M Analog users = 4/ 40
175 M Mobile users = 0/ 0
176 M Advanced IP users = 1/ 20
177 M SIP users = 0/ 0
178 4645 Voice mail engine = 1
179 M 4645 users = 39/ 80
181 OmniPCX Enterprise = 1
182 4645 networking = 0
183 4645 additional language = 0
184 Integrated Gatekeeper = 0
185 SIP Gateway = 1
186 E-CS redundancy = 0
187 H323 (G711) network link = 0
188 SIP network links = 10
189 CCTI agents = 0
190 RSI call center agents = 0
191 Campus DECT = 0
192 DREX Protocol = 0
193 Embedded voice guides = 1
194 4645 Portal users = 0
195 CCD profile = 0
196 RSI Business agents = 0
197 M G729A Client = 0/ 0
198 G723.1 Client = 0
199 Version 4400 R5.0 Ux = 0
200 4400 Mobiles migration = 0
308 M Remote extension = 0/ 0
309 XML telephony = 5000
310 M CLIP Z = 0/ 0
311 ACR Networking = 0
312 Scripting agents = 0
313 eCC Gateway = 2
314 4635 My messaging users = 0
316 M Standard Reflexes users = 14/ 0
317 M Standard IP users = 19/ 0
318 XML IPTouch-IP engine = 0
325 IP-Touch Security Engine = 0
326 M Secured IP-Touch Phones = 0
327 M IP-Touch Security MCM = 0
328 M IP-Softphone Attendants = 0/ 0
329 M IP-Softphone Agents = 0/ 0
330 M Advanced Mobile IP-Touch Users = 0/ 0
332 M PCS max. number = 0/ 0
335 M Greeting Assistant = 0
467 ARS = 80
468 Product Type = 9999
469 G723.1 Server = 32
Have you created the GhostZ extensions needed for 4980IP?
• Create the Ghost Z used by « Nomadic » feature
/users/create
Directory number : Enter a free directory number 31150
Directory name : Enter the name you want ghostZ
Directory first name : Enter your first name you want nomadic
Set Type : +Analog +Analog
Ghost Z : + True + True
Ghost Z features : + nomadic + nomadic
• Create the IP trunk group in case of Nomadic VoIP mode use
Is your Ip Trunk operative?
iourid
Post by iourid »
Hey there,
What is your OTUC version and what is your 4980 version?
On the OTUC side you cen get a snapshot of used licenses:
/opt/Alcatel/FlexLM/lmstat -a
And there is FlexLM log under /opt/Alcatel/logs/FlexLM/lmlog.log
I had something similar (but I think it is different then your problem) after power outage, when all PCs got shutdown but OTUC server didn't. Error message I had was "The license associated to this user is not correct", restarting otucd solved everything. However as far as I remember we got some fixes for 4980 (new lmflex.dll), it was OTUC 3.0.7 long time ago so I don't remember details.
Thanks much
ID
ebolar
Post by ebolar »
Thank you for the hint!!!
The problem is an hardware problem (network interface) of an Softphone Client! Seems he logged in several times ( automatic login)!?!?!
Is there any newer version than V1.0 of the SoftPhone Cliens????
---------------------------snip--------------------------------------
[root@degisl10 FlexLM]# ./lmstat -a
lmstat - Copyright (c) 1989-2004 by Macrovision Corporation. All rights reserved.
Flexible License Manager status on Tue 1/16/2007 11:39
License server status: 27000@degisl10
License file(s) on degisl10: /opt/Alcatel/FlexLM/alcotuc.lic:
degisl10: license server UP (MASTER) v9.5
Vendor daemon status (on degisl10):
ALCFIRM: UP v9.5
Feature usage info:
Users of ECCSTART: (Total of 50 licenses issued; Total of 0 licenses in use)
Users of 4980SOFTPHONE: (Total of 40 licenses issued; Total of 38 licenses in use)
"4980SOFTPHONE" v1.0, vendor: ALCFIRM
floating license
Barm* PCJb PCJb (v1.0) (degisl10/27000 2106), start Tue 1/16 8:26
Beh* PCCB PCCB (v1.0) (degisl10/27000 3108), start Tue 1/16 9:42
Beh* PCCB PCCB (v1.0) (degisl10/27000 605), start Tue 1/16 9:46
Beh* PCCB PCCB (v1.0) (degisl10/27000 2406), start Tue 1/16 9:50
Beh* PCCB PCCB (v1.0) (degisl10/27000 1507), start Tue 1/16 9:54
Beh* PCCB PCCB (v1.0) (degisl10/27000 2008), start Tue 1/16 9:58
Beh* PCCB PCCB (v1.0) (degisl10/27000 2607), start Tue 1/16 10:02
Beh* PCCB PCCB (v1.0) (degisl10/27000 905), start Tue 1/16 10:06
Beh* PCCB PCCB (v1.0) (degisl10/27000 1206), start Tue 1/16 10:10
Beh* PCCB PCCB (v1.0) (degisl10/27000 506), start Tue 1/16 10:14
Beh* PCCB PCCB (v1.0) (degisl10/27000 2511), start Tue 1/16 10:18
Beh* PCCB PCCB (v1.0) (degisl10/27000 3807), start Tue 1/16 10:22
Beh* PCCB PCCB (v1.0) (degisl10/27000 1005), start Tue 1/16 10:26
Beh* PCCB PCCB (v1.0) (degisl10/27000 1308), start Tue 1/16 10:30
Beh* PCCB PCCB (v1.0) (degisl10/27000 4007), start Tue 1/16 10:54
Beh* PCCB PCCB (v1.0) (degisl10/27000 3007), start Tue 1/16 10:58
Beh* PCCB PCCB (v1.0) (degisl10/27000 3908), start Tue 1/16 11:08
Beh* PCCB PCCB (v1.0) (degisl10/27000 3506), start Tue 1/16 11:12
Beh* PCCB PCCB (v1.0) (degisl10/27000 3207), start Tue 1/16 11:16
Beh* PCCB PCCB (v1.0) (degisl10/27000 2810), start Tue 1/16 11:20
Beh* PCCB PCCB (v1.0) (degisl10/27000 2309), start Tue 1/16 11:24
Beh* PCCB PCCB (v1.0) (degisl10/27000 112), start Tue 1/16 11:28
Beh* PCCB PCCB (v1.0) (degisl10/27000 2907), start Tue 1/16 11:32
Beh* PCCB PCCB (v1.0) (degisl10/27000 1407), start Tue 1/16 11:36
Hild* JHNTBR50P JHNTBR50P (v1.0) (degisl10/27000 208), start Tue 1/16 9:13
Rog* PCPRXP PCPRXP (v1.0) (degisl10/27000 3306), start Tue 1/16 8:57
Se* aspcxp aspcxp (v1.0) (degisl10/27000 1905), start Tue 1/16 9:01
Se* aspcxp aspcxp (v1.0) (degisl10/27000 2709), start Tue 1/16 11:07
bo* pcmb pcmb (v1.0) (degisl10/27000 1605), start Tue 1/16 7:42
do* PCVD PCVD (v1.0) (degisl10/27000 1806), start Tue 1/16 7:34
ga* PCHG PCHG (v1.0) (degisl10/27000 1707), start Tue 1/16 9:18
gut* PCGU PCGU (v1.0) (degisl10/27000 2208), start Tue 1/16 7:06
nor* PCDNXP PCDNXP (v1.0) (degisl10/27000 3610), start Tue 1/16 7:16
ot* FO-L3 FO-L3 (v1.0) (degisl10/27000 1108), start Tue 1/16 8:48
rie* pcri pcri (v1.0) (degisl10/27000 806), start Tue 1/16 9:40
sc* PCTS PCTS (v1.0) (degisl10/27000 4106), start Tue 1/16 9:08
sc* PCTS PCTS (v1.0) (degisl10/27000 3413), start Tue 1/16 11:18
we* PCIB PCIB (v1.0) (degisl10/27000 705), start Tue 1/16 8:19
Users of DASHBOARD: (Total of 40 licenses issued; Total of 0 licenses in use)
Users of eCC_Framework: (Total of 1 license issued; Total of 0 licenses in use)
Users of MYPHONE: (Total of 40 licenses issued; Total of 0 licenses in use)
Users of MYPHONETUI: (Total of 40 licenses issued; Total of 0 licenses in use)
Users of MYPHONETHICK: (Total of 40 licenses issued; Total of 0 licenses in use)
Users of MYPHONEWEB: (Total of 40 licenses issued; Total of 0 licenses in use)
Users of MYPHONEEXT: (Total of 40 licenses issued; Total of 0 licenses in use)
Users of MYPHONENOE: (Total of 40 licenses issued; Total of 0 licenses in use)
Users of NUMBERTTSLANGUAGES: (Total of 2 licenses issued; Total of 0 licenses in use)
Users of OTUCRELEASE: (Total of 4 licenses issued; Total of 0 licenses in use)
Users of MYASSISTANT: (Total of 5 licenses issued; Total of 0 licenses in use)
Users of MYASSISTANTTUI: (Total of 5 licenses issued; Total of 0 licenses in use)
Users of MYASSISTANTTHICK: (Total of 5 licenses issued; Total of 0 licenses in use)
Users of MYASSISTANTWEB: (Total of 5 licenses issued; Total of 0 licenses in use)
Users of MYASSISTANTEXT: (Total of 5 licenses issued; Total of 0 licenses in use)
Users of MYASSISTANTNOE: (Total of 5 licenses issued; Total of 0 licenses in use)
Users of MYMESSAGING: (Total of 5 licenses issued; Total of 0 licenses in use)
Users of MYMESSAGINGTUI: (Total of 5 licenses issued; Total of 0 licenses in use)
Users of MYMESSAGINGTHICK: (Total of 5 licenses issued; Total of 0 licenses in use)
Users of MYMESSAGINGWEB: (Total of 5 licenses issued; Total of 0 licenses in use)
Users of MYMESSAGINGEXT: (Total of 5 licenses issued; Total of 0 licenses in use)
Users of MYMESSAGINGNOE: (Total of 5 licenses issued; Total of 0 licenses in use)
Users of API_Framework: (Total of 1 license issued; Total of 0 licenses in use)
Users of MYPHONEAPI: (Total of 40 licenses issued; Total of 0 licenses in use)
Return to “GENERAL”
