4300M - Help to Assess For Decommissioning
VoiceServices
Post by VoiceServices »
I have been given the task of decommissioning a 4300M.
I need to assess the impact on users still at site.
I have cut & pasted a partial dump below I need to interpret where the port number & extension number, also what the feature/service codes are.
STATION OUTPUT ACCORDING TO CRITERION
0 : End of stations output
1 : By mcdu
2 : By directory name
3 : By equipment
4 : By station type
5 : By facility category
6 : By pub. net. category
7 : By metering category
8 : By connection category
9 : By cost centre
10 : By facilities
11 : By operator number
12 : By station function
13 : VOICE SERVICE subscribers
14 : Analog stations with lamp
15 : ( DC) Stations authorized ISDN supplementary service
16 : ( SM) Stations consulting UUS with secret code
17 : ( CI) Stations referring to install. secret code
18 : ( TA) Stations with teleactor function
19 : ( ) Forwarded stations
20 : Output by multi-occupation function
Your choice : 1
OUTPUT USER STATIONS
Automatic output of user stations (Y/N): y
MCDU [ASS] DIRECTORY NAME EQT TYPE FC NT MT CX CT AT F VM L DC SM CI TA
204 [240 ] LANDMARK 861 T_ANALOG 1 22 2 4 - - ad . X . . X .
205 [240 ] INSURANCE 862 T_ANALOG 1 22 2 4 - - ad . X . . X .
206 LANDMARK -1 T4021PL 1 3 2 4 0 - ad . . X . . .
208 LANDMARK 994 T_ANALOG 0 3 2 4 - - ad . X . X X .
210 SPARE 12/8 155 T_ANALOG 0 2 2 4 - - ad . X . . . .
211 SPARE 12/8 652 T_ANALOG 0 2 2 0 - - ad . X . X X .
213 LANDMARK 182 T_ANALOG 1 3 2 4 2 - ad . X X . . .
214 VMAIL008 DIALOUT 156 T_ANALOG 1 4 2 0 - - ad . X
Can anyone advise what mcdu stands for ... is this the port / time slot.?
What is [ass] is this assigned number?
Thanx
Lindsay
goldy
Post by goldy »
ok, it's been a while, but I think this a dump from the command 'post'.
The eqt field is the port, which is in the ofrmat SU-board-terminal eg, 1-3-2
MCDU is an extn number
[ass] is the associate, which calls forward to on no answer etc, most of the time, it will be Voicemail
Hope this helps, i'm pretty rusty on these old clunkers :D
VoiceServices
Thanx very much appreciated
goldy wrote:ok, it's been a while, but I think this a dump from the command 'post'.
Thanx this helps me a lot. Post the Decommissioning I have to provide a solution for the 5 users left at site. 200 odd users have been relocated, thus will be decomissioning the 4300 & replacing with a smaller key system for the 5 refugees.
Return to “ON SITE TROUBLES”
