how to create a SIP TRUNK in OXE VMWare application
alcatelboy
Post by alcatelboy »
how to create a SIP TRUNK in OXE VMWare application,thank you.
alcatelboy
had done, it had created as RACK CS. i will paste the step.
thanks!
arminas
Post by arminas »
i install oxe simulation like this
http://slimphony.blogspot.com/2006/10/o ... setup.html
can you paste your sip configuration on VM
thanks
Donkilla7
VMware
Post by Donkilla7 »
I get this error on my serial output "dhcpcd[29]: timed out waiting for a valid DHCP server response" and a popup message from PC installer 'DHCPD': Produced the following error message:Lease conflict at 192.168.222.2
I can't also modify the Ethernet Address on PC Installer - The box is disabled with a text "not needed"
finaluser
Re: how to create a SIP TRUNK in OXE VMWare application
Post by finaluser »
alcatelboy wrote:how to create a SIP TRUNK in OXE VMWare application,thank you.
Yo can download the installation document from this link http://pastebin.alcatelunleashed.com/?d ... amples.pdf
finaluser
Ok, one question, i have my VMWare with My OXE and a Genesys on it with a 4068 and it works fine...no public calls but for basic tests works nice.
I tried to create a SIP Trunk, it's ok, UP and on trkstat 1 i see all channels F
However when i try to register and extension and make a call i get:
(1)xa000000> 26/10/07 02:25:46 000001M|19/00/0/000|=3:4099x003=B channel choice error No 0 link 1 out 1
If the 4068 calls, the SIP User rings but when tries to answer a 503 Service Unavailable error raises...
Any idea why? Do i need some board for this to work? I thought not...
Any advice will be welcome or any similar experience making this work
Have you checked the B channel's choice under second level of configuration for your SIP TG?
The only time I got this error was the first time I have configured SIP TG + users. It was a configuration error. I don't remember exactly the cause (just trying to guess with my question - I know that B channel choice must be set to yes for a SIP TG).
Also check:
-IP parameters -->direct RTP YES
-System-->Other System Param--->External Sig param --->Progress or Connect for QSIG GF NO
For preliminary tests you should create 2 SIP users and use them for tests.
Don't forget to configure Gateway parameters (subnetwork number declared in your SIP TG and TG number)
Regards.
Ok I checked all and was as that:
This is my SIP trace...Any idea why it doesn't work?
** UNIX-trace-daemon started ... (static user group No 1) **
traced started ...
1193694313 -> RECEIVE MESSAGE FROM NETWORK (192.168.1.17:50195 [UDP])
OPTIONS sip:192.168.1.70:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.17;rport;branch=z9hG4bKc0a80111000000104727a71500002a
180000003f
Content-Length: 0
Call-ID: FED33B9D-0A72-45A2-AC5E-64B2B97E36B5@192.168.1.17
CSeq: 40 OPTIONS
Max-Forwards: 70
To: <sip:192.168.1.70:5060>
1193694313 -> [isUserRegistred] result=-1.
1193694313 -> [CMotorCall::onReceiveRequest] request for gateway.
1193694313 -> [CMotorCall::onReceiveRequest] state = INITIAL_STATE.
1193694313 -> [receiveOptionsMessage] Call: FED33B9D-0A72-45A2-AC5E-64B2B97E36B5
@192.168.1.17 eqt: -1 INITIAL_STATE received a message.
No problem with compatibilities
1193694313 -> SEND MESSAGE TO NETWORK (192.168.1.17:5060 [UDP]) (BUFF LEN = 478)
SIP/2.0 200 OK
Allow: INVITE, ACK, CANCEL, BYE, NOTIFY, REFER, SUBSCRIBE, OPTIONS
Contact: sip:192.168.1.70
Supported: replaces, timer,100rel
User-Agent: ABS GW v5.1.0
To: <sip:192.168.1.70:5060>;tag=fc8bca7ecf30493514da9eaef851f486
CSeq: 40 OPTIONS
180000003f
Content-Length: 0
1193694314 -> RECEIVE MESSAGE FROM NETWORK (192.168.1.17:50195 [UDP])
INVITE sip:3000@192.168.1.70 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.17;rport;branch=z9hG4bKc0a801110000001c4727a71700001b
c500000041
Content-Length: 337
Contact: <sip:1010@192.168.1.17:5060>
Call-ID: D4FE69D3-BAB7-4AD9-A770-8477FF21EB81@192.168.1.17
Content-Type: application/sdp
CSeq: 1 INVITE
From: "unknown"<sip:1010@192.168.1.70>;tag=40200717114993
Max-Forwards: 70
To: <sip:3000@192.168.1.70>
User-Agent: SJphone/1.60.289a (SJ Labs)
v=0
o=- 3402769815 3402769815 IN IP4 192.168.1.17
s=SJphone
c=IN IP4 192.168.1.17
t=0 0
a=direction:active
m=audio 49156 RTP/AVP 0 8 3 97 98 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:3 GSM/8000
a=rtpmap:97 iLBC/8000
a=rtpmap:98 iLBC/8000
a=fmtp:98 mode=20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-11,16
1193694314 -> [CMotorCallManager::callFactory] For call : D4FE69D3-BAB7-4AD9-A77
0-8477FF21EB81@192.168.1.17.
1193694314 -> SEND MESSAGE TO NETWORK (192.168.1.17:5060 [UDP]) (BUFF LEN = 298)
SIP/2.0 100 Trying
From: "unknown" <sip:1010@192.168.1.70>;tag=40200717114993
CSeq: 1 INVITE
c500000041
Content-Length: 0
1193694314 -> [CGwMngData::isAuthenticationRequiredForThisClient] 192.168.1.70 .
1193694314 -> [isDomainFromGwExt] Host from request is : 192.168.1.70.
1193694314 -> [domain not from an External Gateway.
1193694314 -> [isUserRegistred] getRegistration=3000.
1193694314 -> [isUserRegistred] result=-1.
1193694314 -> [CMotorCall::onReceiveRequest] request for gateway.
1193694314 -> [CMotorCall::onReceiveRequest] state = INITIAL_STATE.
1193694314 -> [onReceiveRequest] nb available licenses=9999 .
1193694314 -> [CGwServAuthenticate::isUserDeclared] 1010@192.168.1.70
1193694314 -> hostname == cpu name or IP address......
1193694314 -> [CGwServAuthenticate::isUserDeclared]  found in the dictionnary.
1193694314 -> [CMotorCall] presumed to be the same Dialog
1193694314 -> [onReceiveRequest] Invite => update the inviteContext.
1193694314 -> [CForkedBranch::CForkedBranch] context = 0xbffff2f4.
1193694314 -> [onReceiveRequest] CAC = 0
1193694314 -> [receiveInviteMessage] Call: D4FE69D3-BAB7-4AD9-A770-8477FF21EB81@
1193694314 -> [checkSdpValidity] Sdp contains 1 media description(s).
1193694314 -> [checkSdpValidity] Media 0 type 1 contains 6 formats.
1193694314 -> [checkSdpValidity] Format : 0.
1193694314 -> [convertSdpIntoTsdp] Sdp contains 1 media description(s).
1193694314 -> [convertSdpIntoTsdp] The audio media contains  6 format(s).
1193694314 -> [convertSdpIntoTsdp] Format 0 is 0.
1193694314 -> [convertSdpIntoTsdp] Format 1 is 8.
1193694314 -> [convertSdpIntoTsdp] Format 2 is 3.
1193694314 -> [convertSdpIntoTsdp] Format 3 is 97.
1193694314 -> [convertSdpIntoTsdp] Format 4 is 98.
1193694314 -> [convertSdpIntoTsdp] Format 5 is 101.
1193694314 -> [convertSdpIntoTsdp] Get the direction.
1193694314 -> [convertSdpIntoTsdp] Direction is sendrecv.
1193694314 -> [convertSdpIntoTsdp] The connection is at session level.
1193694314 -> [convertSdpIntoTsdp] Connection address retrieved in sdp: 192.168.
1.17.
1193694314 -> [convertIPStrIntoTuipv] 192.168.1.17 => 192.168.1.17
1193694314 -> [emitEventToMonitel] content size (lginfo): 648
1193694314 -> [ipc_thread] IPC Thread : Ipc reception.
1193694314 -> [ipc_thread] IPC Thread : TCL thread signaled.
1193694314 -> [CMotorCallManager::insertCallwithEqt] CMotorCall 512 inserted.
1193694314 -> [emitEventToMonitel] Event sent on eqt : 512
1193694314 -> [display_ipc_out] ------------ Begin ---------------
1193694314 -> INVITE
1193694314 -> REQUEST URI : 3000@192.168.1.70:5060 ; user=name
1193694314 -> FROM : <unknown> 1010@192.168.1.70:5060
1193694314 -> TO : <> 3000@192.168.1.70:5060
1193694314 -> CAC : 0
1193694314 ->   CAC ADDRESS :
1193694314 -> CLIR : 0
1193694314 -> SDP :
1193694314 ->   ADDRESS : 192.168.1.17 :49156
1193694314 ->   ALGOS :
1193694314 ->     PCMU
1193694314 ->     PCMA
1193694314 ->     101
1193694314 ->   DIRECTION : SEND & RECEIVE
1193694314 ->   N_GW_EXT : -1
1193694314 -> [display_ipc_out] ------------- End ----------------
1193694314 -> [exec_ipc] in.
1193694314 -> [display_ipc_in] ------------ Begin ---------------
1193694314 -> neqt : 512
1193694314 -> SERVER FAILURE
1193694314 -> xx :        3
1193694314 ->   RELATIVE REQUEST : INVITE
1193694314 -> [display_ipc_in] ------------- End ----------------
1193694314 -> [CMotorCallManager::onIncomingEvent] an event 10768 arrived on the
 eqt 512.
1193694314 -> [CMotorCallManager::onIncomingEvent] state = PROCEEDING_STATE.
1193694314 -> [onIncomingEvent] SERVER FAILURE arrived.
1193694314 -> [receiveServerFailureEvent] Call: D4FE69D3-BAB7-4AD9-A770-8477FF21
EB81@192.168.1.17 eqt: 512 PROCEEDING_STATE received an event.
1193694314 -> [receiveServerFailureEvent] incoming call.
1193694314 -> SEND MESSAGE TO NETWORK (192.168.1.17:5060 [UDP]) (BUFF LEN = 375)
SIP/2.0 503 Service Unavailable
To: <sip:3000@192.168.1.70>;tag=d1a80cc05cf618f7df14f3d78c1bb2f4
CSeq: 1 INVITE
c500000041
Content-Length: 0
ACK sip:3000@192.168.1.70 SIP/2.0
c500000041
Content-Length: 0
CSeq: 1 ACK
Max-Forwards: 70
Not sure about this but maybe a SJPhone configuration problem. Here is a trace made by me on my laboratory: viewtopic.php?f=47&t=3007 + configs for SJ Phone used. Try to load one of the configs into your SJPhone (place it on "SJPhione installation path/Profiles), adapt it to your configuration (IP adresses, domain, user, user password) and place the trace to see a call using similar settings.
If it isn't a SJPhone configuration problem we would at least ruled that out.
Regards.
Return to “Other”
