Oxo IP User Home Office
SGE
Post by SGE »
I have oxo R5.1 with CPU3, VoIP4-1 and IP user license. My Home Office is to get 4068 IP over ADSL. Wich i have to config now? ARS ? IP-Adresses? Do you have a technica dokument? Do you have en example of the configuration?
Thanks.
henk1964
Post by henk1964 »
Start with making a VPN tunnel to the office.
Next add an IP extension.
On the new extension go to IP (details) and use the mac adress of the 4068.
Power up the 4068, if you want to manualy edit the IP setting press I # and make the correct IP settings. (do not forget to save with the Top left button)
Test it on the local network first so it can download and upgrade first.
The IP you have to use on the OXO is the voip master.
Once this works unplug the phone and take it home and make the correct setting for the home network. Still use the IP of the master Voip.
SGE
Post by SGE »
Hi Henk,
thanks a lot for your information and the downloadfile (oxo R6) on your Website. Thats great.
Return to “GENERAL”
