Play With Option 82 information and DHCP Scope
cedric1
Post by cedric1 »
Hello
I close the other post about this subject as I saw I haven't post the good file.
Here it is
nguyenhaitoan2008
Post by nguyenhaitoan2008 »
hi,Celdric1
Thanks for useful post.
Can you send me config file of OS6400?I config dhcp option 82 but it doesn't work.I don't know the problem is.Maybe the OS6400 or the DHCP server(Windows server 2003 enterprise).
My email address:nguyenhaitoan2008@gmail.com
Thanks very much.
cedric1
Post by cedric1 »
what did not work ?
send me your output.
Did you get option 82 value on your server ?
nguyenhaitoan2008
Hi Celdric1,
Thanks for your reponse.
Finally,I found the problem is Windows Server 2003 Dchp Server doesn't support DHCP Option 82.
slixxboy
Post by slixxboy »
hello sir I can't open your attachment since this may addition to my next assignment. Do I have a favor to open this? Thanks sir
cedric1
Post by cedric1 »
Ok is good to know
Windows ....
dangkita
Post by dangkita »
So as u said, option 82 in 6400 is the same with 6850?
cedric1
Post by cedric1 »
hi
yes it is.
same options
6400 and 6850 are the same switch but 6400 is L2+ basic routing, no ospf, bgp, pim etc
testerlessi
Post by testerlessi »
i'd like to assign dhcp-ips per port (6200/6250 edge, 6400 aggregation) and am looking for example configurations for dhcp-servers (preferably w2k8, but isc would also do it).
i can't download the pdf, does it contain the hints for this problem and could i obtain it somewhere else?
cedric1
Post by cedric1 »
send me your email as private message , I will send it to you
yes this can solve your issue as option 82 contain port source
