Change operator
thanhnguyen
Change operator
Post by thanhnguyen »
I have 2 extensions which is operator. After 3 ringing if the first operator don't pickup it auto forward to second operator, now I would like to change extension of second operator to another extension, please show me how to do that.
Many thanks
Thanh Nguyen
alliance
reply
Post by alliance »
Normally its in Attendant Groups,
select Group index where the first operator is,
then at the right hand side select Dyn.Rout
in distination No. you will find the second operator number just change in manually then press ok
Return to “MAIN”
