DTMF feature in SIP Trunks
jonnel_ponesto
Post by jonnel_ponesto »
We configured a SIP trunk connected to a Provider, calls were fine however if there is a need to use the DTMF feature the client cant dial the extension they want to call. Is there a possible way we can use that feature in a SIP Trunk?
Thanks,
Jonnel
autodtmf in TG
OR For create for the 40xx set a key with dtmf transparency
yudh1z
Post by yudh1z »
find out whether the the provider using inband or outband dtmf. I also facing the same problem when i tried to connect to 3rd party IVR, it seem the OXE only support the outband dtmf
Jonnel,
Most of SIP is using G711 codec, but some like Verizon are using G729 in the USA.
This will make a difference in the DTMF (inband / outband).
Can you figure it out and let us know ?
jonnel_ponesto
Hi Frank,
Thanks for the advice, I made some adjustment in Timer 299 and it seems the DTMF is working.
Thanks again,
Jonnel
Return to “SIP”
