Upgrade to 8.1.0.b5031
agiftel
Hi, does some had upgrade to this last release? I upgraded to this rel and whole sistem become very very slow. Access to web admin page, logging on from MyIC and Web as well.
I thought was my upgrade wrong, or something into old sistem so I decided to have a scratch installation but with very surprise I get same issue. Whole sistem is too slow!!!!! Any experience???
Thanks guys.
Thanks guys.
banfield
Last time I were upgrading directly with new release i had some hard issues on two of the upgrades.
Slow access to web page this I have been experience before in earlier releases. Restart have then helped, but Is not the issue here.
I have no suggestions then make an e-SR and this maybe helps us that will upgrade later
Please keep us updated...
Arno
Arno
agiftel
I had same issue!! eSR helped me. You have to restart the following service: " muxer " ( service muxerd restart ), as root naturally. I faced same issue two or free times and always solved doing that. It seems issue is linked to creating VM for presentation ( at least in my case was due to it ).
Hope I helped you.
Bye
Hope I helped you.
Bye
Arno
I helped myself
thank you for posting. My solution was to built the VM (I didn`t built it before).
Now everything is working fine, except the presentation feature
But now I have an open eSR
Where do you get the root PW? There is one in the BICS documentation (R2.2), but it is not working for my MyTeamwork server.
Kind Regards
Arno
Kind Regards
Arno
agiftel
Arno
I hope my problems are solved....
Hello, thank you for your reply.
The problem with the slow websites was not solved - I forgot to configure the Outbound SIP Proxy (OXE), now it is solved.
For the presentation issue I did a new installation of the VM with MS Windows 7 prof. (single key, no muli key supported) - same problems as before. At the end I started the DcomFix.exe from A (disk) - now everything is working I hope!
Arno
Arno
agiftel
