IPTouch 4038 reset
Locked
KaMe
IPTouch 4038 reset
Post by KaMe »
Hi All,
i,ve got a problem with several iptouch 4038 (Extended Edition).
They reset all the time. All other 4038 non EE work fine.
R6.0.1-f1.603-1-e-ge-c80s1
Business identification: R6.0.1
Release:
DELIVERY f1.603
Patch identification: 1
Dynamic patch identification: e
Country: ge
Cpu: c80s1
ACD VERSION
release : 6
bug_fixing : 0
protocol_id : 86
version_dy_hr_stat : 11
incvisu shows:
22/04/10 13:20:42 001001M|19/04/0/014|=3:0378=IP Phone sig incident 11,(19,1),00:80:9f:8d:12:f8:00,662
22/04/10 13:20:42 001001M|19/04/0/015|=3:0378=IP Phone sig incident 11,(19,1),00:80:9f:8d:12:2d:00,661
22/04/10 13:20:42 001001M|19/04/0/034|=3:0378=IP Phone sig incident 11,(19,1),00:80:9f:8d:12:41:00,669
22/04/10 13:20:42 001001M|19/04/0/033|=3:0378=IP Phone sig incident 11,(19,1),00:80:9f:86:50:dc:00,664
22/04/10 13:20:42 001001M|19/04/0/028|=3:0378=IP Phone sig incident 11,(19,1),00:80:9f:8d:12:7a:00,779
22/04/10 13:20:42 001001M|19/04/0/032|=3:0378=IP Phone sig incident 11,(19,1),00:80:9f:8d:12:f2:00,557
22/04/10 13:20:43 001001M|19/04/0/035|=3:0378=IP Phone sig incident 11,(19,1),00:80:9f:8d:13:03:00,775
22/04/10 13:21:21 001001M|00/00/0/000|=4:0426=NOE terminal reset 10,(0,0),00:80:9f:8d:12:f8:00,662
22/04/10 13:21:21 001001M|--/--/-/---|=0:1603=IO1 driver error, wrong telephone msg received, line 4076, position (19,1,254)
22/04/10 13:21:21 001001M|--/--/-/---|=3:1607=ff.00.9a.00.00.00.13.01.3c.fe.01.ff.ff.ff.ff
22/04/10 13:21:21 001001M|--/--/-/---|=3:1607=15.04.9f.00.05.05.01.00.6f.01.03.ff.ff.ff.ff
22/04/10 13:21:21 001001M|00/00/0/000|=4:0426=NOE terminal reset 10,(0,0),00:80:9f:8d:12:2d:00,661
22/04/10 13:21:24 001001M|00/00/0/000|=4:0426=NOE terminal reset 10,(0,0),00:80:9f:8d:12:f2:00,557
22/04/10 13:21:24 001001M|--/--/-/---|=0:1603=IO1 driver error, wrong telephone msg received, line 4076, position (19,1,254)
22/04/10 13:21:24 001001M|--/--/-/---|=3:1607=ff.00.9a.00.00.00.13.01.3c.fe.01.ff.ff.ff.ff
22/04/10 13:21:24 001001M|--/--/-/---|=3:1607=15.04.9f.00.05.05.01.00.6f.01.03.ff.ff.ff.ff
22/04/10 13:21:25 001001M|00/00/0/000|=4:0426=NOE terminal reset 10,(0,0),00:80:9f:8d:13:03:00,775
22/04/10 13:21:25 001001M|--/--/-/---|=0:1603=IO1 driver error, wrong telephone msg received, line 4076, position (19,1,254)
22/04/10 13:21:25 001001M|--/--/-/---|=3:1607=ff.00.9a.00.00.00.13.01.3c.fe.01.ff.ff.ff.ff
22/04/10 13:21:25 001001M|--/--/-/---|=3:1607=15.04.9f.00.05.05.01.00.6f.01.03.ff.ff.ff.ff
22/04/10 13:21:26 001001M|00/00/0/000|=4:0426=NOE terminal reset 10,(0,0),00:80:9f:8d:12:7a:00,779
defence 99 shows:
-011 000-00:01:20.680 reset__: [10] ua3g_tsc_reset_message (551 ua3_tsc.c)
-010 000-00:00:02.540 code: 4.10.62 data: 4.10.62 sysdate:
-009 000-00:00:45.680 code: 4.10.62 data: 4.10.62 sysdate: 22/04/2010-13:21:35
In booting process in 4/5 all downloads failed. I think it's a binary problem. But i'm not sure.
I've allready searched the forum but the right answer isn't there.
tia for your help
tincho.rn
Post by tincho.rn »
Hi. I do not believe EE is supported under that release. You will have to check in tech doc. When you download the release, you have a doc with the hardware supported by that release. Regards
4038EE - works from R6.2
murraya
Post by murraya »
hi, go to ip parameters for the user and turn off reset for update as the software for these phones are not in 6.0
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
KaMe
Post by KaMe »
thx for your hints, but my problem is that an option like "reset for updates" isn't shown in my menu. Is Users --> [setnumber]-->TSC IP USER the right location for this option? In this location it's only available set type, voice coding algorithm, terminal ethernet address, ip address, ip domain number and use of volume in system. That's all.
mgr, 4760i or Omnivista 4760 used for administration?
In old release this item "reset for updates" absent.
KaMe
Post by KaMe »
I'm using mgr an Omnivista 4760.
Ok, thx for your help guys.
CU
murraya
Post by murraya »
last version for this software is f1.603.1.ak I think. Does that one have the feature automatic update in user/ip paramerters? I can't find one running here so not sure.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
KaMe
Post by KaMe »
My solution for this problem is to change all EE-Edition sets with "old" sets.
THX
Locked
Return to “IP”
