PCS not going up
kameldalcatel
PCS not going up
Post by kameldalcatel »
I've a PCS connected via 2MBs ADSL line.
I declared every thing possible in management. When in my lab,it works, but once on site it stays for a while, then says 'NOTOK'.
I think it's a timout problem, or may be a port blocking problem through the VPN.
Can any one tell me where to modify the timing. and what port is used by the PCS.
Thanks.
Did you put the PCS behind a NAT public IP , or VPN ?
kameldalcatel
hi Frank,
That's behind a VPN.
kameldalcatel
the message is "end NOK bad soft release", but the release installed in both CS and PCS is exactly the same : R9.0 h1.301-28-d.
any one can help?
Return to “Passive Communication Server”
