Agito integration with OXE
http://www.AgitoNetworks.com
This document explains how to program the OXE in order to work with AGITO
jaf
Re: Agito integration with OXE
Post by jaf »
tried to download but pdf doc is not there anymore. does it exist a new one ?
victornew
Post by victornew »
Hi Frank,
Would you be able to re-post this integration document again?
Thanks in advance.
Return to “AGITO NETWORKS”
