4760i users and Problem in h130138c
swinstation
Post by swinstation »
hi everybody
I have 2 question :
1.I create 1 user on OXE and both of them(mtcl and my new account telecom) can connect to system by using telnet session now but i can not log in in 4760I throw telecom user is there a way to active 4760i for telecom account?
2.I installed h130138c and I can not find 4760i activation option on other system..........use 4760i......
is there a way to active it without changing patch or software?
thanks
aponterules
Post by aponterules »
4760i is aviable up to patch 34 in r9.0 and from patch 38 to R9.1 is no longer aviable. You can search the forum with this info. I think someone posted the official TC from france
sera544
Post by sera544 »
For your info , in R.9.0 Patch H.1301.38c there is no 4760i, if u need 4760 i u have to use the patch below H.1301.38, then only you can see the Option 4760i in tht system management.
In R.9.1 , 4760i option has been removed, already we have discussed in this forum, click below link
showthread.php?3193-Use-of-4760I/page2&highlight=4760i
cheers,
Pandian
swinstation
and what about my first question?
You say about new user in Linux?
After system restart not allowed account by default will be deleted.
swinstation
no I can log in after restart,now if we imagine it works after restart is it possible to give access to 4760i for new user?
From my point of view - 4760i - tools for installer and new account have no sence. No additional security, no log in maohist and so on.
Different account intresting if you need additional security and differente rights - use 4740/ 4760.
sadim
Post by sadim »
And in addtion, it is not suported by ALU
swinstation
dear vad what is your mean "use 4740/ 4760."?
4760 - Real OmniVista. You can create some users/login (on OmniVista server) with different rights.
4740 - old NMC, not supported but still works.
Return to “System”
