problem!repeatin a digit while dialing
swinstation
Post by swinstation »
hi everybody
in one of my sites when a user dial 1 or any number the pabx repeat this number and the extension dial a wrong number ,in outgoing calls do advice or share your experience please.
swinstation
I heard it has relation with GD but I am not sure
Seller_V
Post by Seller_V »
Maybe it is easier? For example some joker created the speed dial numbers which adds the wrong digits... Unlikely i know but... check it just in case.
Release? Type of external line - ISDN, analog?
swinstation
hi
R7 type of external line is analog lines, and No speed dialing.
sorry for delay I was in trip.
sera544
Post by sera544 »
Hi napo,
I think this issue is related to ur GD, remember DTMF, Tones & digits issues are generated by GD hardware problem, we can't identify exactly and there will be no incidents generated related to erros..so u better replace GD and check it out...
swinstation
i did it but was not success full,even I create new data base and .....change my R.
sera544
Post by sera544 »
Hi napo.
Can u try to change the trunk cos which is used for the trunk lines, instead of using trunk cos 1 DTMF, try with trunk cos 0 decadic style, i don't know this is gonna solve ur issue just a try..
cheers
swinstation
yes I changed
Was correction in release 9 "GD generate wrong double DTMF tones for analog endpoints" (patch 43). In readme from R7 - this problem not found.
Return to “Media Gateway”
