PM5 Expert
dilip
PM5 Expert
How can I get hold of all versions of PM5 for OmniPCX Office?
Thanks in advance.
Thanks in advance.
dilip
Br3t
dilip wrote:Hi
I am after PM5 Expert, so that I can programme/ enable Call Diversion and programme pre-programmble keys on the Adavanced terminals.
Have you got PM5 Easy ? If yes, you're only missing the expert.dll that you may find here http://www.ward.nu/computer/tools/#omnipcx
Cheers
Ensitech
Re: PM5 Expert
Hey all,
I'm not able to register myself in the business portal
I keep getting this error...
Error
The domain of your email address does not match the domain names allowed by your company. Make sure to use an appropriate domain name.
I've desperately trying to get a copy of the PM5 management software so I can connect to my Omni PCX
The computer I had which has the software has died (it's missing a config file out of the system 32 folder) so i've not go any way of connecting at the moment and i've got issues backing up that I need to sort out
Any Help would be really appreciated!!
Error
Ensitech
Re: PM5 Expert
Hey all,
Is there anywhere else this software if available form? I'm having registration issues on the ABP and i've got heaps of issues building up that I really need to get sorted and can't do a thing without the software.
The PC that had the software on has died so i'm trying to download it to my new machine - can anyone help??
Guzganel
Re: PM5 Expert
Hello
I'm having the same problem (old windows xp pc died)
On the new Windows 7 pc the old software does'n start ... I have used on xp PM5 310 and 410 but both are crashing on Win 7 when I try to connect to the PBX (Alcatel OmniPCX Office)
Can anyone help with a newer version that works on Windows 7 ? .. or at least please tell me what is the newest version of PM5 so I can furthermore search for it.
P.S. I can make a FTP server if anyone can help
Thank you, in advance !
FrancoYanez
Re: PM5 Expert
I need the installer version R400_17.1b.
Can someone send it to me?
