QSIG rerouting on Alcatel
darkman
Post by darkman »
I have two stations - OXE R7.1 and Avaya S8300 with 2 bidirectional E1 links with QSIG protocol. All communictions is OK, but wa have one problem - call rerouting (another name - deflection) is not work. When call from OXE to Avaya is redirected by operator to OXE - we have two busy trunks.
In Avaya - QSIG rerouting is licensed and enabled. Can OXE support this function ?
If Avaya redirects the call I don't see why Alcatel should support it.
Did you put a tracer on one redirected call to see what Avaya sends you? Maybe Avaya sends you something that OXE can't translate.
Also check the Connection Category between the 2 trunks in Avaya and OXE.
Regards.
knightr1der
Post by knightr1der »
I think Darkman is after Route Optimisation.
You need to create a prefix for that feature from what I have seen. Though, I have never used it myself so I may be wrong.
alex
Post by alex »
QSIG-GF call deflection is supported since Release 3.
Check with t3 what is send if redirection and how OXE reacts to that.
alurfe
Post by alurfe »
check in SYSTEM if Route Optimisation is TRUE and create in TRANSLATOR/PREFIX the PABX ADDRESS in DPNSS (use a prefix with only numebrs not *,#, or A,B etc).
Trace with t3 the protocol on q-sig link.
best regards
Return to “GENERAL”
