Software Upgrade
failure.ehia
Software Upgrade
Post by failure.ehia »
Does anyone can help me with my Problem. I was advice to have software upgrade on my OXO without performing LOLA. Can anyone give me a manual if what is the proper procedure in software upgrade? Thank you...
In OMC - you have Help - read about Tools/ Software download. May be this info will be enough.
Return to “Configuration”
