Calls between SIP extension and IP phone.
Tha Tawa'S
Post by Tha Tawa'S »
Hi, i got a sip call trouble.
I have configure 2 SIP extension and 2 IP phone 4068 on my OXE R9.0.
I can see 2 sip extension registered on my oxe with "sipregister".
I can call an Ip phone with the other IP phone. the reverse is true.
I can call an SIP extension with the other SIP extension. the reverse is true.
My ip phones can call my SIP extension (Linphone on Iphone).
But my SIP extension cannot call my ip phone. I got a dismiss message.
I don't use compression and i don't know what to do now ....
Has someone already had this trouble????
please, help.
Direct RTP enabled? What framing does the Linphone use for g711? CAC activated? If used as SIP device same problem?
Tha Tawa'S
After holidays, i come back with good news.
I didn't set multi-line keys on IP phone, it is better now.
thank you.
Shame on me ;-)
swinstation
Post by swinstation »
did you finf your problem?i have your problem too please tell me if you find solution
Tha Tawa'S
Yes my problem is solved.
Just programmed 'multi-line' keys with extension number on IpPhones and it works.
Hope that will help you.
swinstation
it is weird,I will try it.
Return to “SIP”
