Invalid Attrib. ID when setting "Use of 4670i" to
sandra
Post by sandra »
Hello
Im trying to set the 4670i attribute to True. But when i save it (CTRL+V), it comes back with this error message: Invalid Attrib. ID
Any idea why it won't let me save the new setting?
Thx Sandra
Can you make any other change in the DB ?
sandra
Post by sandra »
frank wrote:Can you make any other change in the DB ?
Thanks for the prompt reply Frank.
Can you suggest what other (test) change to try? I will post the result back ASAP.
Thx Sandra
What pbx release is it ?
Were you able to make changes in the database ?
Are you on the MAIN cpu ?
sandra
Post by sandra »
frank wrote:What pbx release is it ?
1. Please see below. It is version 7.1
2. I don't know what sort of change I need to make? Pls advice.
3. Im connected Telnet. I am in the main CPU.
Welcome to calmain
Alcatel OmniPCX Enterprise
login: mtcl
Password:
Last login: Wed Mar 7 03:49:33 from 192.168.239.250
standard installation last performed: 21-Feb-2007 15:50:18
# The role of the CPU is MAIN
Application software identity
R7.1-f5.401-11-e-us-c80s1
Business identification: R7.1
Release:
DELIVERY f5.401
Patch identification: 11
Dynamic patch identification: e
Country: us
Cpu: c80s1
ACD VERSION
release : 6
bug_fixing : 1
protocol_id : 90
version_dy_hr_stat : 11
Any kind of change.. Can you add a user ? Is MAO locked ?
sandra
Post by sandra »
frank wrote:Any kind of change.. Can you add a user ? Is MAO locked ?
Yes, I can add users. As a matter of fact I just configured a couple of new users this afternoon.
do a checkdb, reboot, and try again
sandra
Post by sandra »
frank wrote:do a checkdb, reboot, and try again
I get a consistency with the database:
(E)ippbx> checkdb
Data base checking in progress ...
/................ERROR 4351 : DATA INCONSISTENCY, Table ENTITY, entity=0 invalid
cdt
(E)ippbx>
I did reboot after I run the checkdb command. Do I need to repair the database? This is a fresh install of the switch; i don't understand how the db could have gone corrupted.
Please advise,
Thx S.
First of all, if you did not change the prompt, and if you have a (E), it means error.. What happened after reboot ?
Return to “GENERAL”
