checkdb errors
checkdb errors
I have some errors (checkdb)
ERROR 2671 : TRANSLATOR PROBLEM for mcdu A6922 st=3
ERROR 4351 : DATA INCONSISTENCY, Table TYPNBAB, Inconsistency Translator=60
May be someone know which table (and parameters) I need to edit with cuser?
TYPNBAB - as I understand - speed dial number?
Eliott
Re: checkdb errors
Post by Eliott »
Yes. It's for speed dialling. The second one should be the numbering plan (tabtrad). You can see the table relations in the file obj2tbl.
Return to “System”
