had a wrong message "smart values read failed" in the vmware .
alcatelboy
Post by alcatelboy »
Wrong message:
Smart Values Read failed: Input/output error
hda: drive_cmd: status=0x41 { DriveReady Error }
hda: drive_cmd: error=0x04 { DriveStatusError }
why ,how to do .
thx
yudh1z
Post by yudh1z »
I had the same problem, does it affect your OXE functionality
alcatelboy wrote:Wrong message:
why ,how to do .
thx
BR_3984
Re: had a wrong message "smart values read failed" in the vm
Post by BR_3984 »
Hello
I have the same error messages on my OXE (R9.1) VM, after a quite successfull installation.
The same series of messages below is reported by CPU each few minutes :
_____________________________________________
Does someone know what the reason could be and how to solve it ?
Many thanks in advance.
sadim
Post by sadim »
Those are smart tool output logs. Deactived the smart tool (check smartctl command)
Sadim
BR_3984
Post by BR_3984 »
Hi Sadim
Thanks for the valuable recommendation.
But in my case it seems impossible to deactivate it. I use the follwong command "smartctl -d /dev/hda" (which seems to be the right one) and get the following answer from the system :
Smart Disable failed: Input/output error
Smartctl: Smart Enable Failed
Obviously the issue has to do with the virtualization with WMWare, but I did not notice any malfunction on the application level.
sadim
Post by sadim »
smartctl is being invoked by an internal oxe process. So, the easiest way to stop these errors is to replace that executable by something that does not do anything. Example:
login as root
cd /usr/sbin
mkdir smarttool_bck
mv smart* smarttool_bck
touch smartctl
chmod +x smartctl
Sadim
Return to “Other”
