Internal from other phone system that the TAQUA T-7000 is connected from and to the Alcatel system. I do not see any incoming from the outside world and can not make outgoing calls. If calls are made internal to the TAQUA T-7000 on Nortel switch the calls come in fine.
Any Idea's
Sip Trunks with TAQUA T-7000 as the SIP box
rogermorse
i am in the process of detailing the config,
I am in the process of detailing the config and waiting on the cofig for the TAQUA system from the customer.
rogermorse
Update -- more testing was done and there were settings in teh TAQUA box that were done and it is possible to get calls in, but not from all area's. Cell phones fail from certain area's as well as land lines. Do not see anything coming into Alcatel switch when the failure happens.
Will keep posting updates if issue gets resolved.
rogermorse
Update on this issue -- Issue has been resolved, the issue was in the TAQUA box with some parameters for signaling.
Set up in the Alcatel-Lucent switch is just like a regular SIP external gateway and Trunk group.
I am trying to find out the settings in the TAQUA box for connection with Alcatel-Lucent switch. Once I find these out I will post the findings
